Broken rear Stabilizer
Yesterday my friend and I rotated my tires and as we were removing the rear passenger tire he noticed that the stabilizer was broken. I was freakin out as I do not know much about cars. He told me its nothing serious, he told me that when I turn I'll here a noise, in which he is absolutely correct as I have noticed some noise when I made a right turn. Anyways how serious is this? would I need to get this replaced ASAP? or its completely ok? also how much am I looking to spend if I get it done in a shop?
It's a 2002 TL.
It's a 2002 TL.
anyways, hope its the endlinks that are broken. in which case you should take a look at Moog endlinks, they're a lot beefier
stock one for Tl is 48 bucks...don't ask me how I know...
Ok...let's say it involves installing the coilovers and removing that nut/threading with the allen wrench and an impact wrench.
Dumbass I am.
Either way, not too big a deal, just didn't handle as well.
Dumbass I am.
Here ya go...
http://www.cardomain.com/ride/184466/6
I did it a couple months back, very easy, no special tools required
You might want to be prepared to have to cut the endlinks off, as the hex key may get stripped.
Cut it off and don't bust your knuckles while stripping the bolts like I did. Much easier to just cut it off. The Moog endlinks are a huge improvement over OEM and I got the rears at Advanced for $24.99 each, front were $20.99 each. Damn my car handles and steers nice and tight now.
also...when installing and uninstalling...use a second jack to take the load off the endlink and get the hole to line up with the bolt coming thru...makes it a lot easier...also spray with wd40 and you may be able to thread all the way up and back out without the need for the allens key. I was able too and made it a lot better when working in such a tight space!
you were able to get the endlinks off without the hex key?!
sure was...if you use a second jack to take the pressure off the assembly and spray with some lube, you can finesse it off without holding it in place. Once it gets to a certain tightness it holds itself without the need for the allens wrench at all.
i just realized something... not trying to question your process BUT...
you have a newer TL
you live in FL and never see snow and salt
hahabut seriously, were they rusty?
x2, exactly this is the right way to do it to avoid stripping it.
No sir...cruddy yes, rusty NO! Plus, the other side one was a new one since I banged up the stock original one with an impact hammer and and ACTUAL hammer! Friggin bringing a damn gun to a knife fight...it'll get ya every time.
MonkeyTrucker
Oct 9, 2015 07:53 PM
Sep 17, 2015 09:01 PM
