Broken plastic headlight bullb holding clip
Old May 6, 2009 | 10:48 AM
03tlCHARCOL's Avatar
WIP-Work in Progress
So you know the metal spring thats suppose to hold the HID headlight bulb in place. Well I accidently broke the overhang plastic which the clip slides into, so the clip wont stay down. The piece of plastic was so small I couldn't glue it back on, so how can I make the clip stay?
Old May 6, 2009 | 10:59 AM
jjashaa's Avatar
Avant Garde Wheels
you can't?
Old May 6, 2009 | 11:05 AM
Rockstar21's Avatar
The Dumb One
^^ so helpful lol i have about the same answer though
OP just look into buying another one. not sure exactly what your talking about. but glueing (<sp?) something plastic near an HID bulb probably wouldnt work anyways...
Old May 6, 2009 | 11:19 AM
jjashaa's Avatar
Avant Garde Wheels
^ well, it holds the bulbs in place..
if that part is broken and the metal clip can't hold the bulb in place.. then the bulb isn't gonna stay.
you can probably put the bulb in... hold the clip down and JB weld the clip down and hope that your bulb won't die by the time you have a replacement headlight...
Old May 6, 2009 | 12:19 PM
The picture doesn't show it that well, but 6 goes into 10, which is fine. But the metal clip holding 10 in place, which is PITA, is tucked under a plastic overhang which then holds the bulb in place. I mean I guess I can just put the back cover on and risk the bulb moving.
Old May 6, 2009 | 12:42 PM
Found a better picture, so you see the screw and the metal spring. Well I broke off a small piece of plastic that holds that clip in place, right under that screw...
blacktsxwagon
Oct 27, 2015 10:12 PM
SUPRMN84
Oct 7, 2015 09:46 PM
rockyboy
Sep 29, 2015 12:05 AM
kixo
Sep 25, 2015 03:07 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
