metal on metal
Old Apr 16, 2009 | 05:49 PM
rob-2's Avatar
metal on metal
I'm at 132K, with all the regular service done and no know issues prior that might cause this.
I recently replaced the rotors/pads, tranny fluid and replaced the front (of motor) engine mount.
I now hear, only while accelerating a high pitch whine. I first thought it was a belt/pulley but I cannot not duplicate it while stopped. Sounds like a bad bearing, like a metal on metal whine.
The noise only happens while accelerating, while at a steady speed there is no whine. It's most noticeable around 4K just before vtec.
Thoughts?
Old Apr 16, 2009 | 06:01 PM
SLushhYYY's Avatar
Keep It Simple in
Tranny.
Old Apr 16, 2009 | 08:27 PM
rob-2's Avatar
I'm not certain it's tranny.
I did another run, car was all warmed up. Drove it hard and no noise. So it seems intermittent. It's not a/c because that wasn't on, climate control was off.
Old Apr 16, 2009 | 08:51 PM
It's Clutch's Avatar
Hello Officer
maybe you just had to break em in a lil...
Old Apr 16, 2009 | 09:25 PM
SLushhYYY's Avatar
Keep It Simple in
PM 014ttl or whatever. But im pretty sure high pitched whines= sign of tranny failure.
Along with metal scraping sound= tranny failure. Search.
Old Apr 16, 2009 | 09:28 PM
MurdaZ's Avatar
your fucking retarded
Old Apr 16, 2009 | 09:31 PM
MurdaZ's Avatar
Thoughts?
if only on accel, im leaning towards the axles, but thats not common for it to whine.
my left rear wheel bearing had a weird growling humming noise at 40-60 only and was not a common wheel bearing noise, but ended up changing it and fixed the prob. so it doesnt have to have the same characteristics as a common issue (which a wheel bearing will constant hum at all ranges, mine didnt) can u narrow it down to what side of the car? front back or side to side?
Old Apr 16, 2009 | 09:35 PM
MurdaZ's Avatar
also u just noticed it only after changing ur pads? did u put back the brake pad shims on the brackets? if that is bent it can squeel against the pad, happened to me, and sounded like metal on metal
Old Apr 16, 2009 | 09:49 PM
Gfaze's Avatar
S E L L
+1
Old Apr 17, 2009 | 09:03 AM
rob-2's Avatar
Since it's only experienced under accelleration it doesn't seem to be the brakes.
Yes, I did put the back the shims on the brackets.
Old Apr 17, 2009 | 09:11 AM
JDM Inspired's Avatar
Thumbs up
Whats with all that??......keep it clean like your CAR........
Old Apr 17, 2009 | 09:18 AM
rob-2's Avatar
I should mention I just did some 60-0 stops and everything sounds fine from the brakes afterward. This high pitch whine was not heard from the car this morning.
My wife heard it so I know I'm not crazy... well about this sound.
Old Apr 17, 2009 | 10:50 AM
SLushhYYY's Avatar
Keep It Simple in
Lol, alright.
I'm just saying that when accelerating its usually the transmission that causes a whine. Usually comes from the right wheel well. Does it happen when you decelerate aswell?
If it whines when turning its the ball bearings. Or power steering pump. Check fluid
Brakes dont make a whiney noise. they fucking squeal
Old Apr 17, 2009 | 12:17 PM
MurdaZ's Avatar
Lol, alright.
wow im not even gonna bother.
since it didnt do it anymore i would say forget it, could be that the pads and rotors so new, needed lil time to bed it, to get the coatings off.
Old Apr 17, 2009 | 12:24 PM
rob-2's Avatar
Yeah don't bother.
One thing I did notice was while on cruise at 70mph last weekend I saw a little flux in my rpms. They were holding steady about 2K and they went up/dwon slightly about 50-100rpm each way. That went away about 2 miles down the road.
I didn't think of it until this morning. I guess the best thing is to keep an eye on it until I have regular issues.
Old Apr 18, 2009 | 01:07 PM
rob-2's Avatar
Just an update, it seems that when the throttle is more then half way down I will get the noise.
Thoughts?
Old Apr 18, 2009 | 01:20 PM
adamlee05's Avatar
Thread Police Chief
Could be the power steering or water pump's internal bearing giving out. At cruising speeds with lower RPM it'd be quieter and under acceleration with higher RPM's you'ld really start to notice it. Just throwing a possibility out there
and GTFO Slushy, he's just making a suggestion, right or wrong.
Old Apr 18, 2009 | 01:33 PM
MurdaZ's Avatar
thats weird, if u put it in park and rev it up on the TB, do u hear it? if not only load, then its something with the powerflow from tranny to axles...or can be speed. but since u said earlier its only acceleration, its torque related......bearings are most speed related, but not always.
Old Apr 19, 2009 | 05:11 PM
rob-2's Avatar
I don't hear it if I rev it stopped.
Old Apr 19, 2009 | 09:30 PM
rob-2's Avatar
I change this statement. I can now hear it if I rev the car really hard, it whines right around 4K.
Car was sitting all afternoon around 85F. Started it up and with a/c off reved the motor really hard. Almost hitting 5.5K.
It doesn't sound like a belt, maybe a bearing going on the alternator?
Old Apr 21, 2009 | 07:49 AM
silver2003tl's Avatar
While revving, create some load on the alternator, power steering, A/C, seperately to see if the noise changes. Maybe you can isolate it that way.
Another crazy way is to get the frequency of the noise, with maybe an oscilloscope tied to a mic. Then figure which bearning (alternator/ power steering/ water pump/ A/c) might be spinning at said frequency.
Also to make sure it's not any kind of belt slippage, spray some belt conditioner on them.
Buy the sears mechanics stethscope and just use that to locate the noise. Might be a little scary placing that on rotating parts but that might be the easiest way.
Old Apr 21, 2009 | 08:03 AM
spiro's Avatar
Take the belt off,try revving and .
Some said its process of elimination.
Old May 6, 2009 | 12:45 PM
rob-2's Avatar
It's all but gone away now. I cannot explain it.
AJRozsa
Oct 5, 2015 07:50 PM
AcuraKidd
Sep 26, 2015 04:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
asahrts
Sep 4, 2015 05:55 PM
