Broken motor mount on front of block
Old Feb 3, 2021 | 09:41 AM
TechniKalCancer's Avatar
just picked up a 2002 Acura TL type s and i knew about this problem but the front motor mount is broken on the block and my mechanic said there isn't a way to replace the mount unless we replace it, he suggested weld the block and also said a cheaper solution would be putting a chain around the motor mount and welding the chain to the frame of the car. he said the bolts are tight but most of the threads are gone.
Was wondering if anyone had this happen or if you had some word of the wise that might be able to help me come up with a solution.
2002 Acura TL type s straight drive
Old Feb 3, 2021 | 10:56 AM
Just to clarify, you are stating that the bolts which hold #9 engine mount bracket, on the link below, to the engine block are stripped?
OR
the bolts that hold #5 engine mount, to the front beam, are stripped?
Engine Mount for 2002 Acura TL SEDAN | Acura OEM Parts
Old Feb 4, 2021 | 07:37 AM
Talking to my buddy it seems more like someone tried installing a new motor mount and they left the bolts loose and the previous owner was very inclined to clutch drop the car at every red light. Yes its the number 9 plate. so where the number 9 plate mounts to the block there is a piece of the block is missing (ripped out i'm guessing) from that area and most of the treads for the other two bolts
Old Feb 4, 2021 | 07:40 AM
and i'm also wondering most places i look at online dosent give me a option to select manual or it only shows automatic for the TL type s and was wondering if you had any ideas to why that like that
Old Feb 4, 2021 | 07:51 AM
You must have a 6-speed swapped 02 TL-S because only the 2003 CL-S came with a manual six speed transmission.
Old Feb 4, 2021 | 08:18 AM
I'm figuring that too no wonder the shift boot doesn't fit, yeah im going to need to put the car on a rack and see everything that has been done to it. i just figure if i want to fix that engine mount issue i might as well swap a j32a2 motor into it
Old Feb 4, 2021 | 08:30 AM
If you go that route, consider a J35A3, from an 01-02 MDX.
Does the missing part on the block look like it's in the area, circled in yellow, of the picture below?
Old Feb 4, 2021 | 09:35 AM
yes it does, thats the area that is broken. Thanks for the swap recommendation ill try to find some threads with that swap.
Old Feb 4, 2021 | 09:57 AM
The thread below is from a forum member who swapped a J35A3 into his automatic TL-S.
J35 swap project - AcuraZine - Acura Enthusiast Community
Keep in mind, since you have a six speed swapped TL-S, if you use an automatic J32A2 from a 2G CL-S or TL-S or an automatic '01-02 MDX J35A3, you would have to make that automatic engine six speed compatible.
That would involve taking the J32A2 drive pulley side crank sensor/ sub-harness, TB stopper plate, TB drive pulley, front head cam pulley and backing plate with cam sensors and sub-harness. If you transfer the J32A2 heads to the J35A3 you would benefit because those heads are a little better than the factory J35A3 heads. Theoretically, you would have a J35A3 Type-S.
If you use the J35A3, you would also need the J32A2 water connecting pipe and water passage, since the connections are different for the MDX. You would have to lose the J35A3 intake manifold spacer, to get the hood closed though. IIRC'y, you would need the J32A2 EGR and MAP sensor, as well. They are supposedly different on the MDX J35A3.
P.S. The previous owner must have really beat on this car to mangle the block like that.
Old Feb 4, 2021 | 12:56 PM
Iggy's Avatar
If it's just the threads, why not install some thread inserts like Helicoil or time-sert?
Old Feb 4, 2021 | 01:26 PM
That's a great idea. Heilcoil makes an M10 kit.
He states, though, that the left lower threaded female boss, in the block (see pic), has broken from the block due to abuse.
Old Feb 4, 2021 | 02:13 PM
Iggy's Avatar
Ah, broken block = no bueno. That thing must have been making all sorts clunking/banging noises.
Old Feb 5, 2021 | 09:43 AM
Yea i don't know what the back story of this car is the car Vin number is on co-part when it was in a collision, im guessing this dude bought the car and "fixed it up" aka put the wrong hood and said fuck the bumper. and im guessing that all the broken bits inside like both door cards and some of the interior was him. but what really pisses me off and i think is a sin is the Acura badge on the back he put upside down.
P.S. sorry for the late replies im not use to fourms.
Old Feb 5, 2021 | 09:45 AM
well its not just the treads were ripped out my shop would have been able to fix that but there is a small chunk of the engine block was ripped off where im guessing where two bolts were closes
Old Feb 5, 2021 | 10:32 AM
Ive posted pictures of the car just to give you and idea of the condition of the car if your curious
https://acurazine.com/g/album/20507009
Old Feb 5, 2021 | 10:33 AM
Dude, that is a CL six speed. TL is four doors.
If and when possible, make sure to get a few pics of the engine mount carnage and post them up.
It would be interesting to see what you are dealing with.
Old Feb 5, 2021 | 11:01 AM
i feel like a idiot not identifying this car correctly, was told it was a TL and never questioned it. But this is going to be interesting, when i get home from work today ill make sure to get more pictures.
Old Feb 5, 2021 | 11:20 AM
lol, don't sweat it!
If interested, this is the closest front bumper I count find to your location on car-part.com
2003 Acura CL Hood Assembly-Stock# PP1140 (car-part.com)392 Highway 42
C4392 Highway 42
Conley, GA 30288
The search was for a hood, though it is likely they still have the bumper.
Old Feb 5, 2021 | 12:52 PM
Thanks yeah depending on the price for the front and back bumper i may see if i might as well go aftermarket. the original owner backed into something and pushed the left exhaust tip into the bumper and cracked the back bumper
Legend2TL
Jan 19, 2022 08:07 AM
kasualballn
Jul 27, 2012 12:55 PM
Jose Gomez
Nov 9, 2011 04:47 PM
vinbell
Mar 13, 2008 03:47 PM
binny
Aug 11, 2005 03:05 PM
