Brakes abs??
Brakes abs??
I have a 2000 acura tl with 47,000 miles on it.
I have a problem when a brake normally the car stops fine, but when have to slam the brakes onand when abs engages the front brakes grab but the rear brakes seem to want to grab and the rear of the car shakes alittle. Like the rear brakes don't grab fully.
Has anyone ever experienced this and what are you guesses might be the problem.
have the calipers tested to see how much pressure is coming from each caliper when you step on the brakes. that will determine if you have a seized caliper.. a flush always helps. i flush my brakes every brake job.
Jamus22
Jun 11, 2023 10:08 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
