Both headlight bulbs one side fail same time.
Old Nov 9, 2007 | 11:53 AM
Pepe_LePewe's Avatar
5th Gear
Cool Both headlight bulbs one side fail same time.
As I was leaving work last evening, a friend yelled "hey, your right headlight is out". So I flicked it to high beam (it was on low) and high beam doesn't work either! I have a question about troubleshooting. (1) Isn't it unlikely that both bulbs would blow at the same time or is that a common failure mode? Since the low HID bulb has its own power source (ballast) and (I assume) the more standard-type high beam bulb its own source, what other things/circuitry might the two bulbs have in common to cause both to fail simultaneously? Also (ok I its two questions), whats the best way to troubleshoot the ballast and/or ignitor?
Old Nov 9, 2007 | 12:12 PM
01tl4tl's Avatar
check the fuse boxes for headlight power
there may be a few
swap the hi beams left to right because its easy= see if that works
Old Nov 9, 2007 | 12:23 PM
myTaLizaS3.2's Avatar
there may be a few
x2..
If they were working fine at once, and both didn't work at once, sounds like a fuse to me.
Old Nov 9, 2007 | 02:34 PM
5th Gear
Thanks for the responses
I think headlights are normally on a single fuse, so if that were the failure neither side would work. I will be swapping right side bulbs to left side tomorrow to eliminate failure of both bulbs as the cause. I am still hoping for any other explanations/ causes that would cause failure of both lights on one side while allowing both beams on the other side to work.
HairyMonkey019
Apr 22, 2016 10:50 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
gqdabien
Sep 8, 2015 11:41 PM
