Belts making noise
Old Apr 26, 2007 | 10:30 PM
merkin110's Avatar
Belts making noise
Ever since I installed my UR crank pulley I have been getting a lot of noise that comes from the passenger side of the engine. The sound gets worse when the alternator needs to work harder (for example when I turn my heater on). Its hard to describe the sound, its kind of like a clanking sound. I have already replaced my alternator tensioner assembly and my alternator/AC belt. Both of them fixed the problem temporarly but then the damn sound came back. Has anyone else had this issue? Any help would be much appreciated.
Old Apr 26, 2007 | 10:47 PM
csmeance's Avatar
i am not an expert on the 2nd gen TL, but is the crank pulley smaller/larger than stock? IF so are ou using the right size belt? Also di you make sure the blet was tensioned properly and fitted on to the pullies correctly?
Old Apr 26, 2007 | 11:32 PM
merkin110's Avatar
The crank pulley is smaller than stock and I did use the gates belts that were recommended by unorthodox racing. Also the belts were fitted properly on the auto tensioner.
Old Apr 27, 2007 | 11:52 AM
merkin110's Avatar
bump
Old Apr 29, 2007 | 12:39 PM
merkin110's Avatar
ttt
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
iCrap
Sep 11, 2015 06:21 PM
nash3222
Sep 10, 2015 09:46 PM
