bad worn brake pad.. why?
I own a 2003 acura tl.
Today I was going to change rear brake pads but I didn't
because of bad worn brake pad..
The right side brake pad was almost worn but the left side brake pad was almosst new.
I checked the history of the maintenance and found the rear brake pads were replaced last year but the rotor wasn't mentioned
(This is the used car purchased less than 1year)
I didn't change rear brake yet. I want to find the cause of that. Is it just a bad pad? or rotor? or any other problem?
thank you
thank you
thats not going to fix the root problem of `caliper is not squeezing the pads to cause wear`
thats going to be a bad caliper --good plan to replace in pairs as they get equal use~
how is the brake fluid? wiki hygroscopic for what happens to fluid
and can sieze a caliper
remove caliper from `good pads`- place a 2x4 in caliper (to keep piston from popping out) and have helper operate brakes
ck movement and free return of the caliper piston
pump out some brake fluid to see whats in caliper
01tl4tl (07-28-2011)
and the result was???
hey- ck the rear pads for 3rd tab issue
stick your head under rear of car and look at rotor
Is it shiny all the way across, same as all the other rotors
or is there rust on half its width and shiny on other half = 3rd tab issue
You can DIY grind tab off FLUSH to the backing plate, so it doesnt hit the caliper piston first anymore-making it extend crooked and cause angled pad contact to inner side
for those new: many makers using RL backing plate and selling as TL pad because the dimensions are the same -except they use a raised tab top center for park brake
We use pad with raised tabs on ends only!!
one holds noise maker arm to warn of low pads
the other is empty or may not exist
Is that your wear problem, angled? or flat wearout= from excess use
SidhuSaaB
05-30-2020 12:40 AM
