Back seats wet
Old Apr 26, 2018 | 12:47 PM
nj00tl's Avatar
Back seats wet
where the top and bottom part of my seats meet are soaked. Last night it was pouring on my way home from work. Pulled into a self car wash and was feeling around in the trunk. Nothing was wet up high. The back deck is dry. Back window was dry on the inside but i have a pool of water where spare is. The trunk mat is soaked but everything on the wall of the trunk was dry. I dont even know where to start to diagnose where its coming from.
Old Apr 26, 2018 | 12:50 PM
tail lights, sunroof, sunroof drain.
all possibilities
Old Apr 26, 2018 | 12:53 PM
Tail light gasket,
Common issue on the 2G
Old Apr 26, 2018 | 12:54 PM
nj00tl's Avatar
Sunroof doesnt leak. The drain for it runs down the pillars right? So id have to take the plastics off and check that. Tail lights tho?
Old Apr 26, 2018 | 12:56 PM
you dont think a failed gasket can lead to water passing through!??!?!??
Old Apr 26, 2018 | 12:58 PM
https://www.google.com/search?q=site...hrome&ie=UTF-8
Old Apr 26, 2018 | 02:38 PM
nj00tl's Avatar
I wasnt aware of there being a gasket. I never took them out and previous cars ive owned that i did have to take the tail lights out, i dont recall there being one. Ill check them tho. I only question the tail lights because my back seats wet. I have a metal brace that separates trunk and cabin so to me my first thought is then everything in the trunk would be wet and it isnt.
Old Apr 27, 2018 | 07:48 AM
frankjnjr's Avatar
NOTE: I've worked on countless cars exhibiting water leak issues. I have never seen a tail light, without some kind of seal, between the light and the body! Very unlikely that your rear seat would get wet, due to a faulty Tail Light seal issue. If, as you say, (" where the top and bottom part of my seats meet are soaked."), I suspect you may have more than one problem. (" I dont even know where to start to diagnose where its coming from.") If my car had this issue, the first thing I would do is remove the rear seat, and all the trim from inside the trunk. Remove all the pooling water, leave the windows down and the deck lid open, and let the car air dry outside in bright sun, if possible. I don't remember, if the trunk light stays on with the headlights off and the trunk open, if so, you may want to remove the bulb. After the interior, and trunk areas are completely dry, get inside the trunk, and close it. Have an assistant with a garden hose, run water, around one tail light first. Have your assistant begin using a very light flow of water at first, slowly increasing the flow, to full force. If, no obvious leak is detected, move to the other tail light. If no leak is detected, direct water to the forward edge of the deck lid, below the rear glass, allowing water to flow all along the "trough", or gutter, that runs around the trunk opening. If no leak is detected in the tail light areas, move on to each rear door. If no leak is detected here, open the sun roof, hop back into the trunk, and have your assistant direct a light flow of water, first at the left sun roof drain, than the right sun roof drain, If you have as much water as you indicate, in both the cabin, and the trunk, the source of the entrance point should be obvious. To insure your sun roof drains are working properly, you can have your assistant pour water in each drain, while you are underneath the rear of the car, observing the rubber hose sun roof drain exit points.
Old May 11, 2018 | 08:36 PM
nj00tl's Avatar
Little update
tail light gaskets were allowing a little trickle of water in. Put new gaskets on and that problem is solved but still getting water in trunk. Upon further water test i have a bad rear glass seal. Water is getting in and trickling down into the trunk. I want to fix it properly but i have never pulled a windshield or rear window before. I can see water trickling down the wheel well by the sunroof drain. Good thing is its just one side but still. I just cant see point of entry but being the water was concentrated on the rear window its safe to say its the culprit.
Old May 11, 2018 | 09:53 PM
frankjnjr's Avatar
How much of the rear cabin, and trunk trim, have you removed,, to aid in finding the leak? To confirm, that it's the rear vision glass weather strip seal, you may want to ( Tape Off ) the weather strip. Than re-test it, and see if leak persists. Until you actually identify the source of the leak, you cannot be certain it is fixed! I replaced the front windshield glass in my 85 300CD. If one does this R&R regularly, it's a piece of cake. Even though, I'm modestly handy, mechanically, the next time I need a front, or rear vision glass replaced, I'll be more than happy to pay, to have it done, by someone who knows what their doing!
Old May 12, 2018 | 10:07 AM
Iggy's Avatar
Agree, front/rear Glass can be a real PIA to get right for the DIY'er.
Old May 12, 2018 | 11:26 AM
01acls's Avatar
The back glass needs to be reset. Pay a professional glass shop to reset the back glass.
Old May 12, 2018 | 11:45 AM
nj00tl's Avatar
all the trim in the trunk is out. I made sure the water only ran down the rear glass when testing. When it comes time to fix it i will pay someone to do it. I work too much and just dont have a lot of free time to do things to the car. I find it odd tho that nothing inside the car is wet. My seats were where the top seat and bottom seat meet but i think that was more from the sloshing of the water.
Nicks2001tl
Jul 25, 2013 01:32 PM
TheChamp531
Wash & Wax
Nov 2, 2012 04:52 AM
piggydog
Feb 27, 2010 12:46 PM
jekenus
Feb 26, 2004 03:58 PM
tsxs2k
Nov 8, 2003 06:52 PM
