axle removal question!!
so i ran into the problem while replacing all of my struts and springs that the bolt at the bottom of the suspension fork was stuck into the LCA...so i got around it without having to replace it! after i bought LCA and the fork and new bolt! but from what i hear the LCA is a bitch to replace... so now my problem is that i need to replace the axle on that side!!!! can i slide it out without removing the fork or does that have to be done no matter what!
what are the steps to doing the axle i dont plan on doing any ball joint because i already replaced them.. and every diy i see they say something about replacing a BJ can i just disconect the upper control arm and the axle bolt and tie rod to spindle and get it out with enough room???
thanks ahead of time!
fork needs to come off
NorCalKnuthson (08-28-2011)
