accessing the air filter
Old Feb 19, 2013 | 05:01 PM
Kurtis1234's Avatar
whats the easiest way to access the air filter if you have a CAI? it makes it hang down near the front and its too low to access from under the hood and is blocked by the mudguard underneath. i thought the mudguard would just come off in the one small piece by the drivers side wheel but it appears to be a massive chunk that would require taking the whole bumper off.
So my question is how do i access the filter on a CAI. its a 2003 type s if that makes a difference.
Thanks.
Old Feb 19, 2013 | 05:04 PM
TheMightyQuinn's Avatar
Registered Nonmember
Opening that splash guard is only one bolt and two or three clips on my 2002 TL-S. It should be the same for yours.
Old Feb 19, 2013 | 05:08 PM
Kurtis1234's Avatar
when i checked it out it looked as though the splash guard was one big chunk all through the wheel well. i didn't have it on a jack so i couldn't get the best view. Ill attempt to get a better look under it. thanks for such a quick response.
Old Feb 19, 2013 | 05:16 PM
you don't remove the splash guard, you just open it up to access the CAI filter.
Old Feb 19, 2013 | 05:24 PM
MilwaukeeDave's Avatar
There's like 3 push pins and a screw. The splash guard is plastic. Just pull the pins and screw then pull the guard down. You have to take your wheel off to make it easiest. I'm a bigger guy so I need the room for access.
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
hashbrown
Sep 29, 2015 12:13 PM
