AC diagnostic
Old Aug 26, 2007 | 10:28 PM
georgy_d28's Avatar
AC diagnostic
i searched but found nothing that i could use
i know how to run the air conditioners diagnostic on my car which is a 99 TL but now that i know a code has been set i need to know if anyone has a picture of the meaning
it flashes between 88 and a backwards "L"
can anyone help? i have the manual from an Accord but im not sure if it is the same
Old Aug 27, 2007 | 01:00 PM
georgy_d28's Avatar
does anyone not know?
Old Aug 27, 2007 | 02:15 PM
Mike B's Avatar
What are other symptoms?
The "88" and the backwards "L" is shown on the air conditioning display? If thats the case, I would imagine that its the control unit which sells for nearly $200 at the dealership.
Old Aug 28, 2007 | 04:22 PM
georgy_d28's Avatar
no everything is working fine but occasionally it is very very cold when set to 61 degrees much colder than it should be so i pulled out the manual for my Accord and it show how to run the check by turning on the AC to 60 then pushing the "AUTO and OFF' buttons simultaniously until "88" flashes then it will use the individual segments of each "8" to tell you what is wrong...does that help explain?
what i am needing is the meaning of the two segments lit up in my display
4drviper
Apr 23, 2025 07:13 PM
Tim Giron
Mar 18, 2016 09:50 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
MoAbbas
Oct 3, 2015 07:44 AM
hashbrown
Sep 29, 2015 12:13 PM
