ABS VSA Lights ON
Old Dec 16, 2013 | 07:36 PM
alexb399's Avatar
Exclamation ABS VSA Lights ON
Hello everyone,
I have my VSA and ABS lights on yet again. The first time was after me and a buddy replaced the transmission. I replaced the left front sensor and had not had any problems until now. I am getting the same codes as last time which are,53-1 and I think it was a 14 for the front left sensor. All this happened when the cold front hit here in Texas last week. On my way to work I noticed the VSA was engaged for almost 2 minutes straight, turned off after I noticed, and came back on right before I turned off the car. It has been on ever since. I tried resetting the codes because the FL sensor is less than 9 months old, but the 53-1 comes up immediately. I am going to check the grounds as soon as I get a chance. I wanted to see if anyone could give me any tips on diagnosing this problem.
53-1 ABS Pump Motor Short
Old Dec 16, 2013 | 07:41 PM
alexb399's Avatar
Oh, almost forgot. I have a 2002 Tl type S.
Old Dec 17, 2013 | 02:01 PM
Nicks2001tl's Avatar
Have the codes read it looks like it can be a couple of things.
Old Dec 18, 2013 | 07:13 PM
alexb399's Avatar
I did get the codes read. They were 53 and 14. 53 is for the abs module and 14 is for the LF speed sensor. I checked the grounds they were ok but did nothing to the problem. I checked the car later and the abs light was off, but not the vsa. I think water somehow got into the module with the snow and is starting to dry out. I do remember noticing the VSA turning on intermittently with heavy rain. Still checking into the VSA problem. Thanks anyway Nick.
Old Dec 18, 2013 | 10:23 PM
I am having the exact same issue with my car and it got cold, snowy and icy around here and my car is kept outdoors also going to check the sensors and wires on the wheels see if there is any exposed wire, before I send it off to a shop for proffesional attention.
Old Dec 19, 2013 | 09:19 AM
Mine had a caliper bolt loose, tightened it all is good.
Old Dec 20, 2013 | 04:15 PM
alexb399's Avatar
The abs light went off on its own. I think water somehow made it into the module. The vsa triangle is still on and within a few minutes the vsa turns on.
Glad to hear you got your's fixed. I'll make sure everything is tight.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
