Abs Modulator Help
Old May 27, 2006 | 03:24 PM
nit78's Avatar
Abs Modulator Help
I finally got my car back from the stealership and they told me that I need to change the ABS Modulator on my 03 TL. Has anyone ever done this and is it a hard fix. They quoted me $2000 including the parts.
Also does anyone know if a modulator from any other honda cars will fit the TL?
Old May 27, 2006 | 05:46 PM
PenancE's Avatar
psh if the abs sensor doesnt come up on the dash, i say fuck them..
Old May 27, 2006 | 06:10 PM
TexasHonda's Avatar
Looks like all the 3.2 TL's from 1999 forward are compatible. Check for local used parts w/ following link. I've bought a couple of used ABS modulator units. Take your time and look around a bit. They will usually garuntee a working unit, but you may wind up w/ a non-working unit and have to get another. I found them for your car as low as $60. That sounds a lot better than $2000. Even if you pay for installation, you should be able to get a working unit for well under $500.
If you want to DIY, it's easy to install and bleed an ABS. You will need a 10mm flare tubing wrench to turn the tubing nuts w/o rounding them off.
Car-Part.com
good luck
Old May 27, 2006 | 08:34 PM
AcuraBuddy's Avatar
TLingggggggg
Hmm well what are the symptoms to your problem because I had my brake system bled like 3 times and a master cylinder changed and my pads changed due to soft brakes and lastly the mechanic told me maybe its my ABS Modulator and well i ve been quoted for about 1000.
Old May 28, 2006 | 04:16 PM
PenancE's Avatar
have u actually tested and see if the abs will kick in when u brake hard? why not just test it..
Old May 29, 2006 | 06:03 PM
Mine was covered on extended warranty and i have a 2002 tls......took them 10 days to get the part and install......that price is what they do charge since i had asked the service guy.
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
SUPRMN84
Oct 7, 2015 09:46 PM
Rachel Lu
Sep 27, 2015 09:53 AM
