Abs Modulator Help
Abs Modulator Help
I finally got my car back from the stealership and they told me that I need to change the ABS Modulator on my 03 TL. Has anyone ever done this and is it a hard fix. They quoted me $2000 including the parts.
Also does anyone know if a modulator from any other honda cars will fit the TL?
If you want to DIY, it's easy to install and bleed an ABS. You will need a 10mm flare tubing wrench to turn the tubing nuts w/o rounding them off.
Car-Part.com
good luck
Hmm well what are the symptoms to your problem because I had my brake system bled like 3 times and a master cylinder changed and my pads changed due to soft brakes and lastly the mechanic told me maybe its my ABS Modulator and well i ve been quoted for about 1000.
Mine was covered on extended warranty and i have a 2002 tls......took them 10 days to get the part and install......that price is what they do charge since i had asked the service guy.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
SUPRMN84
10-07-2015 09:46 PM
