99TL trunk drain plug?
Old May 23, 2018 | 01:28 PM
Zeroskillet's Avatar
I cant seem to find where to buy the trunk main drain plug righht in the middle under the spare tire.
any help?
Old May 23, 2018 | 02:05 PM
13 here? https://www.oemacuraparts.com/auto-p...t/grommet-scat
Old May 23, 2018 | 02:53 PM
Hmmm maybe...hard to tell from that diagram.
Old May 24, 2018 | 06:01 AM
frankjnjr's Avatar
Your right Zeroskillet, it is difficult to tell, from the diagram, alone, which is the correct one. Why not measure the hole, than match that measurement, with the dimensions of the grommets listed. You could use a regular tape measure, or, for a more precise measurement, you could borrow, or buy, a digital, inside/outside caliper, on-line, for less than $10.00. In the long term, you will find, such a tool, vary useful, and a great addition, to your tool box.
Old May 24, 2018 | 11:29 AM
01acls's Avatar
That plug is not in the diagram and not available by itself. Pretty sure it's only available if you buy the trunk floor.
​​​​​​The only way to get that plug is probably to pull it yourself at the salvage yard.
FullTilt
Mar 26, 2008 06:33 AM
xasnxkiddox
Nov 21, 2006 11:56 AM
danslvpt
Feb 23, 2005 06:53 PM
CLpower
Jun 20, 2004 05:02 PM
