99TL trunk drain plug?
Your right Zeroskillet, it is difficult to tell, from the diagram, alone, which is the correct one. Why not measure the hole, than match that measurement, with the dimensions of the grommets listed. You could use a regular tape measure, or, for a more precise measurement, you could borrow, or buy, a digital, inside/outside caliper, on-line, for less than $10.00. In the long term, you will find, such a tool, vary useful, and a great addition, to your tool box.
That plug is not in the diagram and not available by itself. Pretty sure it's only available if you buy the trunk floor.
The only way to get that plug is probably to pull it yourself at the salvage yard.
FullTilt
03-26-2008 06:33 AM
xasnxkiddox
11-21-2006 11:56 AM
