99 won't start
Old Aug 4, 2008 | 08:51 PM
99 won't start
Went to the store today and my 99 TL-P wouldn't start when I tried to leave. It wouldn't even try to turn over. No prior symptoms.
Lights and radio work, but I pulled the battery anyway and ran it to an autozone across the street. Tested good. Thought it might be the key transponder so had the wife bring the other set....no good.
Had the ignition switch changed with the recall a few years ago. Does this sound like the swich is dead? If so, how difficult to change myself?
Thanks in advance.
Old Aug 5, 2008 | 08:56 AM
Bob_F's Avatar
Even the ignition switches installed under the recall can and do fail.
My 1999 TL is on its 3rd ignition switch. The second one was installed under the recall and it failed a year or so ago.
The part is about $50 online and you can install it yourself.
Old Aug 5, 2008 | 09:08 AM
Excellent! Good to know it's something I can do myself.
Just as an afterthought, what would the symptoms be if the starter was the one causing the problem?
thanks again.
Old Aug 5, 2008 | 12:44 PM
Bob_F's Avatar
thanks again.
You're welcome.
Here are a couple of threads on the starter with some discussion of symptoms:
https://acurazine.com/forums/showthread.php?t=158365
https://acurazine.com/forums/showthread.php?t=152417
Good luck and post an update when you figure out the problem.
Old Aug 6, 2008 | 06:46 PM
Great info....thanks.
I'll get on it this weekend and let everyone know what I find.
Cheers!
Old Aug 11, 2008 | 04:12 PM
Worked on it this weekend and it turned out to be the starter. Easy to fix though. Two bolts and two wire connections. 30 min to get out, and 15 to put back in.
Thanks again for all of the help.
Old Aug 11, 2008 | 05:01 PM
Bob_F's Avatar
Thanks for the update and congratulations on the successful repair!
It's nice to know that replacing the starter is an easy job.
How much was the replacement?
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
