99 TL sensor Identification
Old Dec 16, 2013 | 05:43 PM
sidearmbandit's Avatar
8th Gear
Can someone please tell me what this sensor is. It's located just below the camshaft in the front cylinder head.
They wires are frayed badly and I want to replace the sensor after doing a head gasket job but I'm having trouble figuring out what it is. I'm guessing a temp sensor?
Old Dec 16, 2013 | 05:50 PM
Nicks2001tl's Avatar
Welcome to Acurazine!
Old Dec 17, 2013 | 06:45 AM
8th Gear
Anybody?
Old Dec 17, 2013 | 08:00 AM
3.2TLc's Avatar
Hey Sidearmbandit, can ya show us a pic of the location where the sensor came from ?
Old Dec 17, 2013 | 08:56 AM
fsttyms1's Avatar
I dont remember if that is one of the radiator fan switches on the 99 or not. Its a thermo switch though. Part # 37770-P8E-A01
Old Dec 17, 2013 | 03:30 PM
8th Gear
Front head (bottom left)
Old Dec 17, 2013 | 03:38 PM
3.2TLc's Avatar
Rad fan switch "B".....maybe the one Fsttyms1 earlier said.
Check an online Acura parts store for a diagram of your '99 model's sensors, to verify the part #.
Also try Rockauto, and look up sensors for your car. They usually have an actual pic of the part being represented for sale. Good luck !
Old Dec 17, 2013 | 03:59 PM
8th Gear
Perfect - Thanks guys!
Old Dec 17, 2013 | 04:01 PM
8th Gear
Also, I assume the sensor that threads into the top of the block under the intake manifold is a knock sensor correct?
Old Dec 17, 2013 | 04:05 PM
8th Gear
That would be this one here....
Old Dec 17, 2013 | 08:57 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Lightbulb Correct
Yes thats the knock sensor.
Are you rebuilding a 99 engine?
Hope it all works out for you.
Old Dec 17, 2013 | 10:05 PM
8th Gear
Not a complete rebuild. Bought a really solid low mileage car with a blown head gasket for next to nothing. Just had the heads redone, new gaskets and I'm replacing anything that I run across that looks shotty (or I broke) haha.
Old Dec 18, 2013 | 06:44 AM
fsttyms1's Avatar
It is that one. I even posted the part number above
Front Cyl Head
Old Dec 18, 2013 | 06:46 AM
fsttyms1's Avatar
That is a Knock sensor. Be VERY careful with that one when you install it. Especially if its your original. The plastic/glue that hold the top part together gets brittle and when reconnecting the wire end to its clip a gentle tug can and will break it. (i have broken 2 of them now)
Old Dec 18, 2013 | 01:00 PM
8th Gear
HAHA - that's why I needed to know what it was, I broke it taking the heads off. I went to unplug it to move the harness around and the two pieces came apart. It just pulled the contacts off inside so it's shot! Preciate all the help!
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
