99 TL Havin problems starting...
Old Dec 10, 2005 | 07:05 PM
manual123's Avatar
Unhappy 99 TL Havin problems starting...
just late yesterday i got in my tl and it wouldnt start. so i turned off the key took it out and tried it again, then again and it finally started. it was the first time it ever didnt want to start. then today i got in my car to warm it up and once again it didnt start. it has about 114k miles on it, the check engin light is on. once it gets running its smooth, and when even it do want to start it dosnt shutter it just starts up..can anybosy help im really lost on this one.
Old Dec 10, 2005 | 08:38 PM
Luke7's Avatar
WNC Real Estate Sales99TL
Sounds like you might have a bad battery. I had one once that kept shorting out internally . It would start the car perfectly then next time it would not. Have it checked at an auto parts store and go from there.
Old Dec 10, 2005 | 10:21 PM
manual123's Avatar
Hmmm i havent thought of that. My car does still have what looks like the orginal battery, it hasnt been changed as long as ive had the car and i dunno what the previous owner did. Its really cold here and its the first time this car has been in such cold weather. we have been seeing some temps in negitives. ill look into that.
Old Dec 11, 2005 | 08:12 AM
derrick's Avatar
At least yours starts ... mine's at the Honda dealership right now ...
Let's hope your issue is inexpensive to resolve.
Old Dec 11, 2005 | 12:38 PM
manual123's Avatar
Actually i tried it again last night and i noticed the green key light blinking and i couldnt remember seeing it blink before. then i noticed it go out and it started up. could there be someting wrong with my key?
Old Dec 11, 2005 | 12:41 PM
optomos's Avatar
I=X - optomos
I think that's just to let you know your key is still in the ignition.
When you tried starting it did it make a click, click, noise or nothing at all.
Old Dec 11, 2005 | 01:22 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
If the green key light is flashing while you're attempting to start the car, it means the immobilizer system can't read your key. If that's the case, the car will just turn over indefinitely but never start (the green key light will continue to flash).
Do this test:
Go out to it, put the key into the ignition and turn it to "ON" position, but don't start the engine. Watch all the lights on the dash. The green key light should come on briefly then go out. If it starts flashing (even when you're not turning the engine over) it means that the immobilizer doesn't recognize your key.
From what you said right now I think I know your problem. You need a new transponder key.
BTW: the green key light should ONLY flash when you turn the car off, not when you try turning it on.
Old Dec 11, 2005 | 10:32 PM
manual123's Avatar
Today i tested out my car, it started up with any problems..the green light didnt flash, i think i might have a bad key. it is pretty weathered. does the key ever go bad on its own? how much are replacement keys?
Old Dec 11, 2005 | 10:43 PM
03CoupeV6's Avatar
If the key's been in extreme hot or extreme cold, or if it's been submerged in water or even dropped, it can act up. It's a simple chip with a code that has to be in the ignition for the car to start. Just get a new key cut, should be $75 or less.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
