99 TL Electrical issue?
Old Jun 24, 2013 | 08:23 PM
Knunder's Avatar
3rd Gear
99 TL, 170,000 miles. Starts fine, then after a minute or two the gauges quit and the motor progressively runs rougher until its almost stalling. Is this some kind of sensor or control module possibly? Any idea if the two are linked? Im assuming they are since they both started today...but I've been wrong before. Any help/ideas much appreciated.
Old Jun 25, 2013 | 06:54 AM
3.2TLc's Avatar
Welcome to Azine!!!!
While it's possible that ya may have an electrical problem, it's more than likely clogged EGR passageways/port. The '99 models were notorious for this. Check the "DIY" sticky about the procedure for cleaning the EGR and TB intake systems for your car. If this does not help, have the electrical charging system load tested for free at any local auto parts store. Perhaps the battery isn't being fully charged ?
Old Jun 27, 2013 | 03:27 PM
Knunder's Avatar
3rd Gear
Update: Borrowed a code reader last night and checked the fault codes. Only code showing was P1457, something to do with the EVAP system from what I could find.
Is this still a possible EGR prob?...or do I have something else going on with the car?
Old Jun 27, 2013 | 05:23 PM
3.2TLc's Avatar
EVAP system can be a "pita". Usually it's a canister vent valve going bad.
But, with your '99 TL....be sure to clean the EGR passageways and TB intake if they have not been done.
Old Jun 30, 2013 | 08:40 AM
Knunder's Avatar
3rd Gear
Well, had time to clean the EGR port yesterday morning. Took the car for a 15 minute drive with no issues. Not a difficult job to do, only took about an hour and a half. Really glad I found this site before I payed someone else to do it, especially since Acuras aren't that common around here and they would have charged me way to much or messed with every part except the real problem! Thanks for the pointers guys!
Old Jun 30, 2013 | 09:00 AM
3.2TLc's Avatar
So, that fixed ya up ???
Yeah, read the "DIY"s and check out any other particular issues which have been experienced by other 'Ziners. It's all right here at your fingertips !!! Good luck.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
brandnewcolony
Sep 12, 2015 10:39 AM
Aug 30, 2015 02:39 PM
