'99 TL - Check Engine Light code:1709
Old Dec 29, 2005 | 01:12 PM
ez99TL's Avatar
Hi all & thx to this site... My question is CEL code 1709, does anyone know what exactly it means? I believe its either tranny related or A/T assembly. But the dealer replaced my tranny few months ago and then I started getting the CEL. Unfortunately they couldnt diagnose correctly at first . But now they its assembely and its not covered in the work they did to the tranny. In any case I got it diagnose outside and they gave me the code 1709... If anyone knows, I'd really appreciate it
Old Dec 29, 2005 | 02:10 PM
mdavisii's Avatar
B93P TL Owner
OBD-II Diagnostic Code P1709:
Park Or Neutral Position Switch Out Of Self Test Range
Don't exactly know what this means, but that is what the code reads.
Old Dec 29, 2005 | 07:15 PM
loud_whispers's Avatar
p1709 is a "Problem in the Gear Selection Switch Circuit".
The trans. gear selection switch is located on the shift lever assembly itself. The mode switch turns on when the shift lever shifts to the sequential sportshift mode. If the shift lever is pushed forward, the UP switch turns on. If the shift lever is pulled backward, the DOWN switch turns on. The transmission then sends signals to the PCM.
Mode switch or up/down switch STUCK ON Failure-
If the mode switch stays on while the shift lever is in OTHER than d4 position or in the sequental mode, ON FAILURE is determined.
Mode switch OFF failure-
If the mode switch stays off while the shift lever is in the sequential mode and up/down switch is actuated several times, OFF failure is determined.
Remove the Battery and battery tray. Remove the air duct tube.
Unplug all the connectors on the transmission and plug them back in. Check to see if any are unplugged. Especially the range switch.
Then clear the code.
If that doesnt work, you need a gear selector switch which has nothing to do with the tranny installation.
good luck
Old Dec 29, 2005 | 08:30 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
yea definately unplug and plug the connections on the trany, i had a code for p1773 and thats because one of the connectors was loose....good luck
Old Dec 30, 2005 | 09:56 AM
melissasain's Avatar
Makes you think twice before going to the dealership don't it? I know I've been there.
Old Dec 30, 2005 | 04:23 PM
Try going somewhere else for a free transmission.
Old Dec 31, 2005 | 09:40 AM
I don't know ANY dealerships around here that would give me a free one, and I have had problems out of mine. I also had a friend and they replaced hers in GA and guess what ...... she has more problems now than she did before. So does free sound better?
Old Dec 31, 2005 | 12:10 PM
fsttyms1's Avatar
Well if your within the 100k they are free, and free are alot better than paying 4k + for a new one. And if she has problems tell her to bring the car back to the dealer!
Old Dec 31, 2005 | 03:33 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
If she had it replaced at Nalley Acura they probably left pieces out or installed it incorrectly. They replaced my dash, my passenger airbag, and my headunit and all three were installed incorrectly. They also did damage to parts every single time.
Old Jan 1, 2006 | 02:15 PM
Smile
I think 03coupe36 summed it up nicely, I would rather pay for it and get it done right than to keep having to cuss the Acura dealership to fix what they keep messing up. Yea, it's free; but we all know free isn't always better.
Old Jan 4, 2006 | 01:52 PM
we know these transmissions better than anyone in the world. that's just foolish to take it somewhere else.
Old Oct 13, 2016 | 07:32 PM
River Roberts's Avatar
its your gear selector switch located next to the gear box.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
