99 3.2 TL squeeking noise......???
Old Mar 7, 2009 | 08:46 PM
jokerjuice's Avatar
Question 99 3.2 TL squeeking noise......???
i recently put tein ss with dampering and i had it on very stiff for the whole summer and a little during winter then i decided to put it on smooth...right now its still on smooth but now im starting to hear this squeeking noise its like when you squeeze a rubber ducky.. its very very annoying. It only occurs when i go over bumps or pot holes..and i only hear it from the back i dont know if its from the seats or the coilover i dont know where its coming from but please if you know anything about this please help me find the solution and hopefully help locate where its coming from thank you.
Old Mar 7, 2009 | 08:50 PM
MurdaZ's Avatar
could be the sway bar bushings.
Old Mar 7, 2009 | 09:02 PM
jokerjuice's Avatar
thank alot for responding quickly. Could that be why its giving that annoying squeeking noise?
Old Mar 7, 2009 | 09:06 PM
jokerjuice's Avatar
ohh and if you get this is it okay if do an alighnemnt when its slammed and if you bring it bak up would if affect the alighnment?
Old Mar 8, 2009 | 05:15 PM
thinhthan's Avatar
im pretty sure it would
Old Mar 8, 2009 | 05:32 PM
twistedwedge's Avatar
6MT Someday..
you will have to get it aligned again
Old Mar 8, 2009 | 05:47 PM
jokerjuice's Avatar
would you have any answer about the squeeky noise that i was talking about before
Old Mar 8, 2009 | 07:15 PM
gold2003tl (90)'s Avatar
2003 TL-p
our lower ball joints are know to have some problems, im not sure if its from lowering, but they do have a history of failing. im sure a stiffer ride cant help the lower ball joints.
Old Mar 8, 2009 | 07:20 PM
2003 TL-p
there are a few arms on the rear suspension links (sway bar bushings maybe) or other links, that could be the problem. just give them a tug and see if any of them are loose or making that noise. im sure the seat is not the problem
Old Mar 8, 2009 | 07:32 PM
jokerjuice's Avatar
ohh perfect ya im going to see my mechanic tomorrow because i cant stand it anymore. i have another question recently i was hearing the front driver side squeaking like a needed a lower ball joint but now i dont hear it anymore should i still change it for safety???
Old Mar 8, 2009 | 08:00 PM
jokerjuice's Avatar
anyone?
Old Mar 8, 2009 | 08:48 PM
jokerjuice's Avatar
anybody?
Old Mar 9, 2009 | 09:23 AM
6MT Someday..
If youre taking it to a mechanic-tell him to give everything a good once over. He should be able to tell if you need to replace anything.
I get a slight squeak sometimes when turning onto an uneven surface, ie my driveway. Just dropped the car though-Im sure its a spring squeak for me.
Old Mar 10, 2009 | 12:00 AM
jokerjuice's Avatar
anyone whos if you take out the acura emblam in the bak if it has to holes or its glued??
mlody
Dec 4, 2019 02:11 PM
Pham Alvan
Mar 16, 2016 09:17 AM
kmarqueling
Oct 3, 2015 01:14 AM
Kitsune13
Sep 24, 2015 02:25 PM
Mike Bertram
Sep 10, 2015 09:27 AM
