2003 tls (noise in cabin)
Old May 7, 2015 | 07:23 PM
frankjnjr's Avatar
so, here is the deal: purchased last june, 196k, no major issues, many updates, t belt, w pump, tensioner, plugs, a/c belt, p/s belt, coolant, p/s flush,brake fluid flush, reseal oil pump, replace oil pan (drain plug strped) pass side eng mount, trans 3x service twice, external trans filter, tires, alignmnt, drivers door check, brake pedal pad, hood struts, pcv valve, manifold and egr service. blower motor, cabin filters, air bag recall 7521H1, f&r pads and rotors, etc/etc/, i love this car, white pearl/ black. currently my only issue one of annoyance. i've searched this forum for clues, but found nothing related to this issue: current miles @208k, there is a NOISE in the cabin. the noise occurs only when turning and sounds exactly like something is loose inside the glove box, it's like. picture the glove box as being empty, except for lets say a small 6" mag light style flashlight laying in the bottom. every time you turn, the flashlight slides from one end of the glove box to the other creating this noise. the noise almost sounds something like a pendulum suspended but hanging freely under the dash and when the car turns, the pendulum slides to the right or left and makes the noise. there is nothing in the glove box. i removed the glove box, both a/c vents, the pass side air bag, the cabin filters, the blower motor, center console, radio/nav and i can find nothing out of order? listening with a stethoscope. the noise sounds like its coming from the area between the nav screen and the glove box? the noise is loud enough so that if i put my phone in the glove box, leaving the glove box open and drive the car i can record it! any one have an idea as to where to look?
Old May 7, 2015 | 08:58 PM
01acls's Avatar
Open your hood and look at the shock towers. You're looking to see if the top hat is center or not to the shock towers. If not centered or not symetrical then the top hat bearing is worn out.
Old May 8, 2015 | 12:03 AM
Chojun's Avatar
Yeah my thoughts are on some kind of suspension issue on the passenger side as well.
Also check that your strut cross member is bolted down right.
Old May 8, 2015 | 03:33 AM
01tl4tl's Avatar
Im thinking cv axle bearing noise
is it with the wheels turned hard- and slow speed = you hear click click click?
Old May 8, 2015 | 06:59 AM
frankjnjr's Avatar
will check and advise. tx
Old May 8, 2015 | 07:02 AM
frankjnjr's Avatar
strut cross member is tight. the noise sounds as if the glove box shock is not attached and rocks back and forth on turns creating the noise.
Old May 8, 2015 | 07:15 AM
frankjnjr's Avatar
tx for the response 01tl4tl, no, its not an axle type noise, it occurs on a mild turn, such as when entering or exiting an expressway ramp, or turning into a parking space in a parking lot etc. it's not a click type noise. lets say the glove box shock was not attached, and as the car turns in either direction the shock hits the side of the glove box or the dash support as it swings from side to side. i'm going to remove the glove box this w/e, have someone else drive the car and try to pin-point the origin.
Old May 8, 2015 | 09:44 AM
Chojun's Avatar
Removing the glove box was going to be my 2nd suggestion, also you might try opening the passenger door and giving it a good hard shake back and forth. Did something fall inside the door panel?
Have you noticed any problems with the heat/ac blower? Does it make any noise when going from fresh to recirculate (and does it do that properly)?
Old May 8, 2015 | 10:30 AM
01tl4tl's Avatar
ck those sway bar end links, I found one bad on my 01-
bad control arm one side, broken end link on the opposite
You already did a ck of each bushing on the control arms?
and bushings for the shock absorbers?
are you running stock suspension?
Imagining possible noises: look in the panel at bottom of windshield- exterior.
If a nut, rock or something got thru the grill, it would roll back and forth!
The fresh air vent inlet is inside that panel = noises transfer~
Anyone who changed their cabin filter knows what a strange array of items can get in
Old May 8, 2015 | 12:56 PM
frankjnjr's Avatar
tx Chojun, a/c door operation is perfect. will try shaking the door but can't feature anything inside door, even if something broke loose making this type noise.
Old May 8, 2015 | 12:59 PM
frankjnjr's Avatar
will chk w/s vent inlet cover panel tonight. great idea as sound could be resonating from inside there, and the w/s has been replaced. yes, stock suspension, everything stock and all replacement parts oem. tx again
Old May 9, 2015 | 06:52 AM
frankjnjr's Avatar
top hat is centered. everything looks good here
Old May 9, 2015 | 06:58 AM
frankjnjr's Avatar
complete ft suspension is tight. stock suspension. removed plastic under hood cowl cover, no debris inside rolling around. removed cabin filters just to see what was inside, found nothing remarkable, vacuumed and reinstalled.
Old May 9, 2015 | 07:02 AM
frankjnjr's Avatar
shook and pounded on door last night, nothing. dought noise is coming from door area. removed glove box and will have a friend drive car today while i try to identify exact area of the noise.
Old May 22, 2015 | 07:11 AM
frankjnjr's Avatar
don't know how or why but the noise is gone. after removing the glove box the last time, the noise has not come back? so nice to drive a rattle free car. thanks for all your help
Old May 22, 2015 | 11:02 AM
01tl4tl's Avatar
reinstalled glove box and no noise?
maybe the shock inside it really was loose and making the noise!
Old May 22, 2015 | 01:23 PM
Chojun's Avatar
Yeah when I removed mine to do the cabin air filter I found that they had to be precicely reinstalled or they wouldn't go in correctly. I'll bet that's what it was.
Old May 23, 2015 | 12:49 PM
01tl4tl's Avatar
There you go! operator error, who woulda thunk
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
