2003 TL-S AC not working
Old Jul 28, 2018 | 04:02 PM
nishant11's Avatar
My repairman informed me that AC is not working because TXV is stuck open and resulting in low pressure side pressure higher than high pressure side
I bought new evaporator and TXV and he assembled it
AC worked fine for an hour but resulted in gradual reduction of air flow resulting in zero flow from vent. If I shut off car for few hours then everything would work fine again for an hour
I thought that I made a mistake of not replacing dryer / receiver causing moisture from air causing TXV icing up thus stopping flow
After changing dryer, compressor was found dead not powering up even after direct powering
I have also changed AC control unit on the back side of flow control knob. Still repairman has not been able to fix the issue
All relays are confirmed fine
Am I missing something?
Please advise
sseiyah
1/2G MDX (2001-2013)
May 15, 2018 12:37 AM
PhilWithers
2G CL Problems & Fixes
Mar 11, 2009 04:31 PM
erb_56
Jan 30, 2009 04:24 AM
jpooncanada
Apr 9, 2007 07:55 PM
