2002 acura tl codes HELP HELP
Old Dec 4, 2009 | 05:46 AM
bama boy's Avatar
how do you check the codes on a acura tl type s please help
Old Dec 4, 2009 | 08:20 AM
gregyb123's Avatar
8th Gear
Well you need a scan tool or just go to Auto Zone and have them scan it for you. The connector is located under the change tray. You have to pull the plastic cover out. Not the tray but the cover under it.
Old Dec 4, 2009 | 01:15 PM
thinhthan's Avatar
you got a o2 so i think it should be under the cover under the steering wheel right?
Old Dec 4, 2009 | 02:23 PM
ac-inblack's Avatar
It's right under the dash to the right of the steering wheel. If you look under its right there and you just plug it in.
Old Dec 7, 2009 | 08:15 PM
FrickinGenius's Avatar
3rd Gear
Isn't there a way to test the climate control system without a scanner? I have seen it with some other Acura models, but can't confirm on an 00 TL.
mada51589
Jan 9, 2025 04:40 PM
iesu3423
Sep 29, 2015 08:04 AM
theinsvnity
Sep 10, 2015 10:22 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
