2001 electical issues -indicators
Old Apr 7, 2006 | 08:08 PM
boe_d's Avatar
Hello,
I've got a couple of indicators that come on for whatever reasons. My brake light is on for the first 5 minutes or so that I use my car - then it goes out.
MY SRS is now on all the time.
Any guesses?
Old Apr 8, 2006 | 12:54 AM
Blazin_TL's Avatar
Registered User
im not sure about the brake light being an electrical issue. that usually means you need brake fluid, your fluid resevoir is probably loose.. as for the SRS i cant help ya there sorry.
Old Apr 8, 2006 | 01:18 AM
optomos's Avatar
I=X - optomos
The brake light issue could be either the filter, cap, or float which is part of the cap on the master cylinder. You can get all 3 for around $20 + tax or shipping.
Old Apr 8, 2006 | 02:11 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Originally Posted by boe_d
Hello,
Any guesses?
I would say first check your brake fluid reservoir. If it is low, add fluid and the light should go off. If it is not low, it could possilbly mean it is time for front pads. I'm only saying this is possible, not likely. I wouldn't have believed this, but this is the way it happened in the Camry.
The SRS light could possibly be due to the OPDS. There is now an extended warranty campaign on these components, so you will be covered there as long as you have less than 150000 miles.
funkbro2
Nov 17, 2015 10:23 PM
knight rider
Oct 1, 2015 10:29 AM
Padre
Sep 19, 2015 09:08 AM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
