2000 Acura TL Remote Programming Instructions
Old Jan 2, 2006 | 11:57 AM
abhay's Avatar
I have 2000 Acura TL. The remote has a FCC ID: KOBUTAH2T. I need programming instructions. I will appreciate help. E-mail: Bhargavaabhay@hotmail.com
Abhay
Old Jan 3, 2006 | 03:09 AM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
Here you go...
You can have a total of three remotes for your car. to program them do the following.
Between each step, wait about a couple of seconds. Also note that it doesn't matter in any of the steps if you use lock or unlock. Just hit one of them:
o turn the ignition switch on. (Note: This is the III position, and you do not have to start your car)
o push the remote lock button with remote aimed at the rec. in the passenger multiplex unit. (This is by the glove box).
o turn the ignition switch off.
• turn the ignition switch on.
• push the remote unlock button while aimed at the rec. You should hear the locks click.
• push the remote lock button.
• within 10 sec. aim the remotes (up to threee) that you want to set at the rec. and press the lock or unlock buttons. When you do this each remote should be locking/unlocking the doors.
• Turn off the ignition and remove the keys.
All the remotes should now work.
Old Jan 3, 2006 | 03:14 AM
TL_Fo_Life's Avatar
https://acurazine.com/forums/showthread.php?t=127807
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
mazen222
Oct 27, 2015 12:01 AM
MikeYutkin
Sep 10, 2015 10:13 PM
Mike Bertram
Sep 10, 2015 09:27 AM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
