2000 Acura TL Clean Solenoids and Replace ATF Filter?
Old Oct 14, 2013 | 12:34 PM
remix919's Avatar
Can anyone link me to the thread showing how to clean the solenoids and where the external ATF filter is? (i thought only the 04+ had these?) My transmission is shifting really hard and starting to slip a little so I was going to try the few quick fixes and hope it helps make it last a bit longer. I've already tried searching these forums for well over an hour and can't find the threads showing the cleaning.
Old Oct 14, 2013 | 12:36 PM
remix919's Avatar
BTW, car has 283k miles but the tranny was rebuilt by an indy shop at around 225k miles.
Old Oct 14, 2013 | 03:05 PM
Nicks2001tl's Avatar
The external filter is below the the rear side of the battery. 4 10mm bolts hold the bracket on to the spin off filter. Once you get to the filter you need if I remember correctly a 17/18 wrench to take it off. Transmission filter replacement is also in the diy section with good instructions.
You can try a few things before replacing the tranny
~Can of lubegard
~3x3 flush
~1/2 can of transtune before the flush (no need for cleaning the solenoids if you go this route)
Note: Try lubegard first only 14 bucks.
Old Oct 14, 2013 | 03:39 PM
remix919's Avatar
~Can of lubegard
~3x3 flush
Thanks, I've tried the 3x3 flush already, and saw the lubegard in some posts so already ordered that and hopefully that should help I'll go try to change the filter tomorrow or so. Is that the only filter to change? I saw in some other threads there are 2 solenoid filters or something?
Btw, where is the DIY section? I'm new here and thought the Problems & Fixes section was it, is there another area I'm missing?
Old Oct 14, 2013 | 04:08 PM
DIY section is on top of the 2nd gen homepage.
Only 1 external filter. Solenoids have screens.
Old Oct 14, 2013 | 06:39 PM
remix919's Avatar
I'm still not seeing the DIY section? Are you talking about those sub-forums?
Old Oct 14, 2013 | 06:40 PM
remix919's Avatar
o, nm, found it, I was looking for a forum, didn't realize it was a thread
Old Oct 14, 2013 | 08:26 PM
remix919's Avatar
Just want to make sure, is this the filter?
https://acurazine.com/forums/2g-tl-problems-fixes-117/transmission-bypass-spin-filter-replacement-852465/
and is there a DIY on cleaning the solenoid screens?
Old Oct 14, 2013 | 10:01 PM
Yikes's Avatar
https://acurazine.com/forums/showthread.php?t=852465
Yes, that is the filter.
As for the solenoid screens, I don't believe there is a DIY but it is pretty straight forward.
When you remove the solenoid, there is a rubber gasket and there are two screens connected to said gasket. One is an oval and one is a circle. Be very careful when trying to peel the gasket off. As to how to get to it, I'm afraid I can't be of much help, but I'm sure there are those here that know how. Hopefully they'll chime in.
Best of luck. I assume you also have a CEL with the P0740 code? Hate to be the bearer of bad news, but usually when that happens it's the beginning of the end. Please keep us updated.
Old Oct 15, 2013 | 07:05 AM
Does your car show any codes?
Old Oct 15, 2013 | 09:29 AM
remix919's Avatar
I haven't checked it with a mercedes specialty shop yet, and I'm assuming the CEL won't show up on an ODB2 scan? I don't have any check engine light or D5 flashing
Old Oct 15, 2013 | 07:12 PM
Yikes's Avatar
Any CEL would show up on an OBD II scan. When ever the computer detects a fault, it throws a code making the CEL come on.
If your CEL isn't on, the computer hasn't thrown a code.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
ibGTV
Sep 28, 2015 03:40 AM
Mike Bertram
Sep 10, 2015 09:27 AM
