104,000.....
Old Jan 22, 2010 | 12:09 PM
Hitlayers's Avatar
104,000.....
What's going on everyone? Just a quick question, I just hit 104,000 miles, what needs to be done? Anything needs to be lubed? Etc....? Thanks!
Old Jan 22, 2010 | 12:15 PM
TLin401's Avatar
'13 Hyundai Sonata
Ball joints, timing belt, upper control arms, your tranny will probably go soon.
Old Jan 22, 2010 | 12:20 PM
Hitlayers's Avatar
I Was told the timing belt should be changed at 105,000 miles, just got everything else checked out, I have time, please do not jinx the tranny...Thanks for your response.....
Old Jan 22, 2010 | 12:23 PM
TLin401's Avatar
'13 Hyundai Sonata
I forgot the belts.
Old Jan 22, 2010 | 01:23 PM
niju321's Avatar
technically spark plugs are due at 105k, but replace them now, they are probably already degraded in performance. use ngk iridium (better) or platinum (oem) only.
Old Jan 22, 2010 | 03:33 PM
fsttyms1's Avatar
Timing belt is 7 years or 105. You are past the 7 years and i would be more concerned about the age than miles. Id get the belt service done sooner than later.
Old Jan 22, 2010 | 03:52 PM
Hitlayers's Avatar
First time I heard the 7 year thing, but ok, thanks!
Old Jan 22, 2010 | 03:53 PM
Hitlayers's Avatar
Did the coils and NGK Iridium plugs 6 months ago. Thanks!
Hitlayers's Avatar
Tranny fluid still pink, so leave it alone??
Old Feb 5, 2010 | 02:29 PM
Black 32TLS's Avatar
Can you be a little more detailed on the upper control arms?
Do you mean replace them? or just the ball joints and bushings on the upper control arms?
I just hit 105K on my car. Need to start some maintenance on this thing.
thanks!
Old Feb 14, 2010 | 03:32 AM
SodaLuvr's Avatar
At 105k you need to replace the timing belt, timing belt tensioners, water pump, drive belts and spark plugs. A valve adjustment also needs to be done. Personally, I would also replace the thermostat and radiator hoses at the same time. This costs around $1200 at a Honda dealer or $1600 at an Acura dealer.
The lower ball joints, upper control arms, etc are all done on an as-needed basis. The transmission should have been serviced at the 90k mark. If it was done then, then it does not need to be done again until 120k. If in doubt, go ahead and service it.
Old Feb 14, 2010 | 02:32 PM
xtremex626's Avatar
Regional Coordinator (SoCal)
:shakehead
pgatour1
Aug 28, 2001 06:13 PM
acuraguynj
May 30, 2001 04:13 PM
PeterUbers
May 24, 2001 09:18 PM
someguy
May 23, 2001 10:18 PM
