100k Check up (info needed)
ChairmanMaoSaysRTFM
for the 100k you'll want to do the plugs, belts, water pump & check your belt tensioner (i only say that because mine needed replacing, so better safe than sorry). you should also replace the woodruff key in your crankshaft pulley. i know you can get woodruff keys at home depot but i don't know if they have one that will fit our cranks. you may want to see if the dealer has any extra ones.
#2 is your water pump, and i would imagine that the gasket (#3) comes with the pump, but order it anyway if you have any doubts.
i can't think of anything else you should do offhand, but your owner's manual may have other recommendations.
Bob
Bob
would you happen to know what the belt tensioner looks like or where it is located? as for belt i would need alt, ps, timing, anything else?
in the process of replacing the water pump, i will also be changing the radiator hoses and do a complete flush of the fluid also replace the thermostat.
yes the tensioner is 18, belts timing, PS and ALT.
nope
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
