'03 TL-S Headlight problem
Old Nov 12, 2013 | 08:02 PM
Bonezanator's Avatar
So my driver side headlight sometimes turns on and sometimes it just refuses to turn on. Has anyone encountered this problem and if you have how'd you fix it? Thanks!
Old Nov 12, 2013 | 09:09 PM
cincinattlguy19's Avatar
06 NBP 6MT TL
I'm assuming you're still with the stock setup... This happened to me and it was the ballast.
It is way cheaper to just get an aftermarket kit than to fix the 10 year old stock HID system piece by piece. Check out ddmtuning or HIDextra for aftermarket kits!
Old Nov 12, 2013 | 09:14 PM
I checked the output on the driver balist compared to the passenger (working) side and they were the same. I picked up a ddm hid conversion kit but couldn't figure out how to install it due to having the old system still. Would i have to completely strip the old system?
Old Nov 12, 2013 | 09:35 PM
06 NBP 6MT TL
Yeah you will just get rid of the old bulbs and igniters (wires attached to bulbs) and can leave the ballasts mounted to the underside of the headlight to keep the gap covered underneath it.
Old Nov 13, 2013 | 05:54 PM
3.2TLc's Avatar
Hey Bonezanator, could be that the bulb was going bad on that side. Check all the connectors and components for signs of moisture or corrosion. Then ya can try swapping sides, installing a known good bulb in the problem side. Ya never know !
Old Nov 13, 2013 | 11:03 PM
01tl4tl's Avatar
bulb death,,was it purple or pink tint at startup recently?
or goes off while driving and comes back with flipping switch a few times? - ignitor prob
time for a new kit to replace all that cheapo stock 10 year old non-waterproof stuff
www.hidextra.com 5000k bulbs 35watt ballast,,all we need for 59$ and coupons!!
cant go wrong,,simple diy
Old May 6, 2014 | 02:36 AM
mstaj10's Avatar
Im having that problem as well. U mean to tell me i can get one of these 80$ hid conversion kits instead of buying a whole new ballast to fix this thing?
Old May 6, 2014 | 06:38 AM
3.2TLc's Avatar
Thumbs up HID replacement kit......
Yep, check the "DIY" sticky for basic installation tips. There are many other previous threads on this subject. Check out the site's sponsor vendors for great prices on aftermarket HID kits to replace your TL's old worn-out system. Less than $100 for a complete kit to replace both sides.
Old May 6, 2014 | 07:46 AM
fsttyms1's Avatar
Yes, just remember you get what you pay for. Dont get the cheapest kit you can find and expect it to be great quality and last for ever. Some times it pays to spend a little bit more and get a known quality kit.
I recommend http://www.theretrofitsource.com/
Old May 6, 2014 | 07:49 AM
06 NBP 6MT TL
Old May 6, 2014 | 08:31 AM
mstaj10's Avatar
Only way u can get these are online?
TLrascal
Aug 3, 2018 11:00 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
MistaWet
Sep 15, 2015 08:26 PM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
