'03 TL-S Headlight problem
I'm assuming you're still with the stock setup... This happened to me and it was the ballast.
It is way cheaper to just get an aftermarket kit than to fix the 10 year old stock HID system piece by piece. Check out ddmtuning or HIDextra for aftermarket kits!
I checked the output on the driver balist compared to the passenger (working) side and they were the same. I picked up a ddm hid conversion kit but couldn't figure out how to install it due to having the old system still. Would i have to completely strip the old system?
Hey Bonezanator, could be that the bulb was going bad on that side. Check all the connectors and components for signs of moisture or corrosion. Then ya can try swapping sides, installing a known good bulb in the problem side. Ya never know !
bulb death,,was it purple or pink tint at startup recently?
or goes off while driving and comes back with flipping switch a few times? - ignitor prob
time for a new kit to replace all that cheapo stock 10 year old non-waterproof stuff
www.hidextra.com 5000k bulbs 35watt ballast,,all we need for 59$ and coupons!!
cant go wrong,,simple diy
HID replacement kit......
Yep, check the "DIY" sticky for basic installation tips. There are many other previous threads on this subject. Check out the site's sponsor vendors for great prices on aftermarket HID kits to replace your TL's old worn-out system. Less than $100 for a complete kit to replace both sides.
I recommend http://www.theretrofitsource.com/
mrkingstonvi
02-22-2016 01:53 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
