03 TL-S A/c Goes from meh-cold to warm.
As usual the search button got the best of me.
Riding in my aunts 03 TL-S again due to getting into a accident with my WRX.
Thermostat was replaced a couple of months ago.
A/c blows somewhat cold while the car is still warming up, then once it is at idle temp it stops blowing cold. A/c compressor takes longer to engage. Once it does turn on it stays for 45-60 seconds and shuts off but still blows warm.
Only when you are moving above 30 does it blow somewhat cold again.
Car doesn't go above the middle of the Water temp gauge, stays in one spot.
Is it something as simple as just getting the a/c system recharged or am i going to need to replace the whole compressor?
Thanks in advance.
Thanks in advance.
Having the AC system checked and charged would be cheaper than replacing the compressor if it's not bad.
Check the #58 fuse (20a) and the AC relay in the underhood box. Then check the #3 fuse (7.5a) in the driver's side interior box. Eliminate the simple stuff first !!!
Either you've got a bad compressor, which I doubt, or a low charge and an inaccurate gauge. Short cycling is often an indication of low charge. Try one of the 12oz cans, and see what happens. Or have it checked out by a professional.
Ok so i turned the car on after it had cooled down all the way and turned on the a/c.
It read 45 PSI with the compressor on and 110 off.
I filled it with a bit of recharge stuff and it went up to about 50 psi while the a/c was running.
Got in the car it was nice and cool. Took it for a spin around the block and it started getting a little warm again and then the coolant temp started rising.
Da fuq is going on here.
Something to check may be the heater valve cable linkage. Could be as simple as needing cleaned and lubed up. Look down the motor's side of the firewall where the heater hoses are located. Have someone operate the inside switch while you watch the heater valve on the inlet hose for free movement. If it's not that, run a self diagnostic of the climate control system. Also check the T-stat, as your temp gauge should stay below the middle mark.
Biggie_B
May 27, 2025 05:51 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
