03 TL Issues
Old Jan 14, 2013 | 06:42 PM
Saaax650's Avatar
03 TL Issues
My car would change the 2nd gear to around 4k rpm in the morning once in a while and sometimes wont engage in to gear.So I have to let go gas and step on it again. It only does this in cold morning. During the day it is fine. Ironically , it doesnot give any check engine light. Honda dealer did Tranny flash in 2011. Is this start of craziness or just need some sensor /solenoid replacement. ALl other gears are fine and sooth shift.I have aoubt 105k Mileage with original tranny
The LCD of temp/Mileage has not light. Is there any bulb that needs changing or any sensor.
Thanks in Advance.
Old Jan 15, 2013 | 05:52 PM
AcraAdi93's Avatar
Do you play around with the sport mode? Mine shifts fine when in D5 auto but in sport mode I sometimes have to do it twice cuz idk what is goin on there. Trans might start to slip slowly. Btw warm up your car for 3-5 minutes every time to get the trans warmed up. If you start and go this could be why
Old Jan 15, 2013 | 08:45 PM
tightnight's Avatar
Thanks in Advance.
you need to take the dash board out. three is a small print board on the back. you need to replace that board also along with 4 red base light bulb. I believe the small board cost $36. mine went out several month ago. I fixed it by replacing it.
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
