03 Blower Motor Fix
Old Sep 22, 2008 | 10:55 AM
LAMike240's Avatar
03 Blower Motor Fix
Guys,
So I have the melted connector...the 2 wire one that plugs into the blower motor. Is the fix to cut this off, spice in a new one and replace the resistor and blower motor? I do see the TSB fix which seems a bit more work....
Any comments please?
Thanks,
Mike
Old Sep 22, 2008 | 11:02 AM
01tl4tl's Avatar
depends if the motor is ok
A good auto electrical shop can make fast work of the repair for you with the right connectors and stuff
Old Sep 22, 2008 | 03:09 PM
LAMike240's Avatar
I've ordered the pigtail from ebay...and will attempt it.
Thanks,
Mike
Old Sep 22, 2008 | 11:27 PM
240sx acura tech's Avatar
acura master tech
the dealer has the sub harness if the pig tail does not work. runs $30.
Old Sep 23, 2008 | 10:26 AM
01tl4tl's Avatar
Is that all the wire set cost? thanks tech!
most would probably do better with a plug and play than splicing the wires in--IMO
Old Sep 23, 2008 | 12:03 PM
9932's Avatar
2G wanting 3G
hey does anyone know if this would effect the heat/ac from only coming out the vents that point at your face and not switching to floor or defrost vents, even when your hitting mode and the arrows are changing on the screen? this is whats happening to me.
Old Oct 3, 2008 | 04:48 PM
2K3_TLs's Avatar
OMGWTFVTEC
The subharness for the blower motor ran me 10 bucks. Picked it up yesterday, and installed it. Took me about 30 min or so, the connectors are a bit tricky to get the terminal out. Alas, the motor is the culprit.
Old Oct 3, 2008 | 06:39 PM
2K3_TLs's Avatar
OMGWTFVTEC
I believe the part number is 04321-S0K-A00 if anyone needs it.
Old Oct 4, 2008 | 11:40 AM
9932's Avatar
2G wanting 3G
hey so say you have the problem where it still blows hot or cold, but you cant choose what vents you want the air to come from. as far as trouble shooting, where would you start???
Old Oct 4, 2008 | 09:59 PM
LAMike240's Avatar
I believe that is the air mix motor.
Old Oct 6, 2008 | 05:50 PM
2K3_TLs's Avatar
OMGWTFVTEC
Does yours still heat/cool the air, but doesnt blow any air through the vents? Thats what mine does. Thought the pigtail would be a quick fix, but now I need a new blower motor.
Old Oct 7, 2008 | 12:49 PM
9932's Avatar
2G wanting 3G
my air, hot or cold, comes out the dash vents. when i hit mode to make it come out through the floor vents it still comes out the dash. when i need the window to defrost it still comes throught the dash. are you saying that getting a new pig tail will fix this problem? or will i need the air mix motor? to tell you the truth i would be fine if it always came though the defrost vent only if theres a way i can rig that.
Old Oct 7, 2008 | 10:59 PM
LAMike240's Avatar
Pigtail has NOTHING to do with your problem. It was the cause of mine in the original post.
Old Jun 2, 2009 | 09:58 AM
zay52184's Avatar
3rd Gear
I bought the blower motor, the motor would turn on for a split second and then turn off, connected new motor same issue, bought a new transistor returned new blower motor, and now I have AC yesssss!!!! considering it is 95 degrees in miami with a lot of humidity!!!
TypeS860
Jan 10, 2026 11:11 AM
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
juanrl
Sep 29, 2015 03:25 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
