02' TL-S P0505 "idle air control system" error
Old Apr 3, 2008 | 03:05 PM
Slunami's Avatar
My 2002 TL-type S is having some idle issues. It's idling and running rough and the RPM's are intermittently shooting up and down when idling. I scanned it and got a PO505 idle air control system error. It's also stalled on my at random when I'm driving at less than 15 mph or sitting at a stop sign. No idea how to handle this, any thoughts? Thanks a million!!!!
Old Apr 3, 2008 | 03:22 PM
'03TL-S's Avatar
most likely it is your idle control valve. take it out and clean it with a small toothbrush. clean your egr port while you're at it. if it still has the same problems, you will probably have to change the IACV.
Old Apr 3, 2008 | 05:05 PM
fsttyms1's Avatar
Take the Idle Air Control valve off the bottom of the Throttle Body and clean it. If that doesnt work you may need a new one
Old Oct 6, 2008 | 07:59 AM
FirePR2002's Avatar
bringin lead
which one is the IACV - anyone with a photo pointing to it?
Old Oct 6, 2008 | 03:22 PM
6MTUA5's Avatar
No He Can't
It's on the bottom side of the throttle body
Old Oct 6, 2008 | 03:44 PM
FirePR2002's Avatar
bringin lead
^^thanks man - that helps.
Old Oct 6, 2008 | 04:55 PM
6MTUA5's Avatar
No He Can't
If you can't locate the bottom of the throttle body, you may want to reconsider
Old Oct 6, 2008 | 04:58 PM
6MTUA5's Avatar
No He Can't
Here's the bottom of the whole intake manifold/throttle body assembly. Since it's upside down, the IACV is on the top of the throttle body here. One end of the looped hose is on the IACV and one is on the throttle body.
Old Oct 6, 2008 | 09:33 PM
FirePR2002's Avatar
bringin lead
thank you - that's what i thought, just wanted confirmation....
Old Oct 6, 2008 | 09:47 PM
6MTUA5's Avatar
No He Can't
It's pretty darn hard to get to, though.. at least for me it always has been. Use a stubby screwdriver to fit in there while everything is still connected.
Old Oct 6, 2008 | 10:39 PM
FirePR2002's Avatar
bringin lead
it was all coming apart anyway - i think if i have to replace it (about 95% certain) i can get it with a stubby though.....
Old Oct 7, 2008 | 10:18 PM
FirePR2002's Avatar
bringin lead
solved my problem...was easy once confirmed, although it was not really an iacv issue.
Old Oct 7, 2008 | 10:43 PM
ftLauTL's Avatar
Ya....It's an Acura
what turned out to be the problem, I just ask because im experiencing a similar issue with my tl
Old Oct 7, 2008 | 10:52 PM
6MTUA5's Avatar
No He Can't
I'd say to also check out/clean your PCV valve
Old Oct 8, 2008 | 08:54 AM
FirePR2002's Avatar
bringin lead
i installed the p2r spacer for the tl-p and the new tb bolts they provided were too short to accommodate the p2r spacer and stock spacer. long story short, it was jimmy-rigged based on bad advice i received. now all is well as i now have the correct bolts, spacer, and stock spacer in the correct order.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Sep 17, 2015 09:01 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
