#$&@! Parking Brake Adjustment, HELP!!!!
My Parking break shoes had to be replaced, and I finally got around doing this today.
Did one side by looking at the other, so I know I got all springs and levers in their right places, but I can't put the rotor back on, well I can force it on with a hammer, but that wouldn't be right. The parking brake drum hits against the parking break shoes and it get's stuck half way.
I know of 2 places where I can adjust the parking break 1) at the parking brake pedal, and 2) on the rear brakes them selves, I checked both places and they're both "loosened" all the way.
Has anyone else seen this? I'm so #@!#$@
mad right now, I just don't get it, what else could be done?
Thanks in advace for any and all suggestions.
'02 TL, Auto, 76k
mad right now, I just don't get it, what else could be done?Thanks in advace for any and all suggestions.
'02 TL, Auto, 76k
Originally Posted by optomos
It should be tight, but without being there I can't tell how tight it really is.
OK, I can understand new brakes being tight, but so tight that I have to hammer on the brake disc really hard? There doesn't seem to be any clearance between the shoes and the drum, is this normal?
I read about new parking brake shoes break-in procedure, but something is setting off a red flag in my brains about trying to install any breaks that you have to force in.
Originally Posted by fsttyms1
you have to adjust them. turn in the (looks like a cowboy boot spur) and it will lessen the outward travel.
Loosen the parking brake cable adjustment also (by the foot pedal). Make sure that the cable is pulled all the way loose. if its slightly pulled it will be expanding the brakes making it impossible to get the rotors on
Thanks for the suggestion though
its possible that the pads are defective. If you wore out 1 side it would lead me to believe that one is hanging up while driving, and was improperly put together or something was wrong to begin with. maybe try getting a different set of pads to compare size and thickness?
...If you wore out 1 side it would lead me to believe that one is hanging up while driving, and was improperly put together or something was wrong to begin with...
Thx for all the suggestions, I'm glad that It wasn't just me being crazzy and that there really are only 2 places this is adjustable.
Any word on what the issue was?
They gave me a loaner, so I don't know if they planned on taking all day or did have some problems and didn't want to admit it. I'm pretty sure that the parking brake shoes was the problem, I bought mine at NAPA, next time I'll go to the dealer for these kind of parts. The dealer only charged me for labor and shoes.
Atleast they got fixed. How ofen do you use it that they wore out.?? Im still on the originals at 200+k and i use it alot
rockyboy
Aug 4, 2024 10:35 AM
