wire tuck stage 1
dreem1er (06-28-2012)
nope no problems, all i'm doing is reruning the lines, its not a full wire tuck as some civics do, i'm not cutting lines just moving them, the only thing that i've cut is the wire loom that holds the wires together
its a clean up, bascially what i did on that side is open up the factory wire loom i left the abs sensor plug to the front, and a small line of wire going to the front, headlights maybe, not sure, and pulled everything else back and removed the mounts and cases,
i moved the plugs for the trans, the small relay box, and a unit that has vacum lines, straight back to the open area back there, i'm probably going to move the battery to the trunk,
suspaction (06-27-2012)
The following 2 users liked this post by 02ACTcLean:
dreem1er (06-28-2012),
floored4door (06-28-2012)
rcs86
08-02-2016 06:52 PM
SUPRMN84
10-07-2015 09:46 PM
