Ummm engine cover..
Old Jan 20, 2005 | 08:10 PM
yunginTL's Avatar
trill recognize trill
Ummm engine cover..
Umm its a little messed up what can I do?
another coat u think would get rid of those finger prints
thats how it looks right now a little fuckd up but i just put it on for the time being until i got time
Old Jan 20, 2005 | 08:12 PM
soopa's Avatar
The Creator
lol. sand... PRIME... repaint
Old Jan 20, 2005 | 08:18 PM
yunginTL's Avatar
lolz first attempt to do sumthin myself
Old Jan 20, 2005 | 08:19 PM
El pana/TL32's Avatar
Old Jan 20, 2005 | 08:23 PM
moahdriven's Avatar
i
try sanding the entire thing with some 800 grit sandpaper. should pretty much even the paint, then jus spray the entire thing with 2 more "not too thick" coats. Wait for it to dry an hour at least before putting it back in.
Old Jan 20, 2005 | 08:32 PM
shimbo519's Avatar
USMC Butterbars
someone got a little excited....lol
Old Jan 20, 2005 | 08:43 PM
jj87's Avatar
yo
this is what i do when something goes wrong for me. cross my fingers an hope that it'll go better next time.
Old Jan 20, 2005 | 08:49 PM
streetracing901's Avatar
yo!
Its not that bad....but Im doin tha same with my dads car this weekend.(I dunno why)
Did you use primer? Try no to rush and do light coats. What happened to your battery cover? When I do it, I plan to paint the engine cover, battery cover and the cover for that little box to the left.....wish me luck...ill post up the results when done.
Old Jan 20, 2005 | 09:13 PM
NYZGREATST's Avatar
Sig Rho's Finest
did you use the right paint? sometimes chrome does that if its the wrong paint for the surface
Old Jan 20, 2005 | 09:33 PM
yunginTL's Avatar
i did chrome on the battery cover
n all that is gonna come off. i used high build primer and used an alumium colored high heat engine paint
Old Jan 20, 2005 | 09:34 PM
yunginTL's Avatar
ur right
Old Jan 20, 2005 | 09:46 PM
yunginTL's Avatar
so ur sayin us tht sandpaper n jus recoat it lightly wit the same paint?
Old Jan 20, 2005 | 10:19 PM
99TLKID's Avatar
L33t Sk8er
IMO you should not have messed with it in the first place.....looks horrid to me
Old Jan 20, 2005 | 10:21 PM
yo!
yep
Old Jan 20, 2005 | 11:23 PM
yunginTL's Avatar
ill do the sandin to the paint n jus recoat it afta i get it back frum the dealer for the tranny recall bringin it 2morrow
Old Jan 21, 2005 | 01:24 AM
alleyesonmeee's Avatar
MIA
Maybe try letting it dry for a long time in between coats of primer / paint?
Old Jan 22, 2005 | 03:04 AM
moahdriven's Avatar
i
cmon man, stop hating on younger ppl so much. U learn from ur mistakes.
Old Jan 22, 2005 | 03:07 AM
yunginTL's Avatar
too much hate on this site for the yunger onez
Old Jan 22, 2005 | 08:37 AM
shimbo519's Avatar
USMC Butterbars
everyone makes mistakes.
Old Jan 22, 2005 | 08:46 AM
fsttyms1's Avatar
its ok, just sand with 220 grit to smooth out, (then 400 wet for best finish) . then the key to painting is MANY LIGHT COATS! dont try to do it all in 1 coat. it will never work that way. many thing coats will build and lay better and look better.. then dont get anxious to put it on. let it sit over night and dry. (you can drive the car with out it) then when fully dry install
Old Jan 22, 2005 | 11:00 AM
yo!
I dont think so.....i love this site!
Old Jan 22, 2005 | 09:17 PM
rolinacura19's Avatar
i would recomend not using the discount auto paint
go to your fav local body shop friend and sand down and do prep work for him and throw him 20$ or whatever to spray and clear......
i did this, and was pretty happy with results..........
Old Jan 22, 2005 | 10:05 PM
yo!
Did you want it like this?!!??! hahaha j/p
Old Jan 22, 2005 | 10:15 PM
ya not bad.....is that factory paint or just silver spray....
any clear coat?
looks alot better then first job lol
Old Jan 22, 2005 | 10:47 PM
Tunaboy's Avatar
Who Dis Is?
What I'd say to do. To get the look right. Be patient and put a coat on, wait an hour, proceed for 3-4 coats and let it dry overnight. You probably wanted to get it on quickly to see the new look (hence the finger prints). Just sand it and take it to a body shop. They'll get it done (airbrushed) for 20 bucks.
Old Jan 22, 2005 | 11:42 PM
yo!
I did mine with a rattle can and 15 bucks.....
Old Jan 22, 2005 | 11:44 PM
yunginTL's Avatar
YES i done it..clear coatin it 2morrow 100x better than those first two pix. ill post 2morrow. No more fingerprints...haha
Old Jan 23, 2005 | 12:25 AM
yunginTL's Avatar
Old Jan 23, 2005 | 12:30 AM
haha always go the nicer route you will always be satisfied.......
Old Jan 23, 2005 | 02:18 PM
yunginTL's Avatar
Finally resanded the paint..used engine high heat paint by duplicolor in aluminum and it came out perfect.
Basically a perfect color match in my eyes
Old Jan 23, 2005 | 02:35 PM
Tunaboy's Avatar
Who Dis Is?
Pics didn't work
Old Jan 23, 2005 | 02:52 PM
yunginTL's Avatar
does this work?
Old Jan 23, 2005 | 02:59 PM
yunginTL's Avatar
i think the host is down
Old Jan 23, 2005 | 03:24 PM
fsttyms1's Avatar
works for me in both!
Looks good
Old Jan 23, 2005 | 04:29 PM
yo!
Looks great!
Old Jan 28, 2005 | 06:18 PM
moahdriven's Avatar
i
niiiiiiiiice job man, looks awesome.
Old Jan 29, 2005 | 02:54 PM
vtlec01's Avatar
Not dissin but IMPO I dont think theres a need to do anything to the engine cover. It looks great shined up and also matches everything else when its black but will say second time came out much much better.
Old Jan 29, 2005 | 04:05 PM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
I give you prop's for trying. Dont let the hate discourage you. Remember If you screw up these guys on the forum know what they're talkin bout and will help you. ( at least i hope so) :blaze:
Old Feb 1, 2005 | 01:40 AM
lokee99's Avatar
I'm stock and hating it.
can you put like a gloss coat on top or just get a glossy paint. to give it that shiny look?
Old Feb 1, 2005 | 10:27 AM
yunginTL's Avatar
i just used an aluminum color engine paint rated at 500 degrees. no glossy coats it was already bling blingin
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
