at the track
i have a 99 FPR bone stock interals.. ran a 15.38 at its fastest if i remember.
even when i used brake torquing or just slammed the gas.. it was only a tenth or two off.. and thats with a good bit of wheel spin too.
maybe your tb isnt opening all the way when you going WOT... maybe the cable has slack?
when i gate shift it it seem like i didnt have vtec. my launching tech was hold the brake and give it some gas. is there anything i do do to the motor like clean something or anything?
trying cleanin the egr port and so forth like in the DIYs
then give it a seafoam.. spark plugs ok?
PSI on tires...
suspension shocks ok? cuz that matters in launching.. motor mounts??
PSI on tires...
i did the egr port cleaning like a year ago. i havent done the valve adjustments yet. i changed the spark plugs with the ngk iridiums about a year ago. i also seafoam when i did the egr. my psi was 35. and i got brand new shocks like a month or two ago. i got the illuminas with tiens s tech springs. i left the settings on the front at 1 and the rears at 3 and i have bad motor mounts and trans mounts
How would you not have vtec. Gate shifting will yield the fastest times. (when shifted just before the rev limiter)
i dont know whats wrong with my car man. i tried seafoam, bg44k, bg fuel injector cleaner, new oil, bg intake manifold cleaner. i dont know
