quick pic of my new system setup
sorry for this idiotic question but what's the glass used for? or is plastic?
Looks, good how much did this set-up cost and what's it putting out? Also did you do the work yourself?
its fiberglass and its used to protect my amps so i can put stuff in my trunk and also it make the light reflect well and the setup was almost 2000 all together and i did the work by myself and my system is putting out 2000 watts 1000 per sub
-pioneer deh-5900ib
-2 kicker 12" L5's
-kicker box ( i cut to fit all the way back against seats)
-Memphis pr.1000w amp
-Pioneer 800w amp
-2 8 gauge wiring kits
-50ft 16 gauge speaker wire
-Fiberglass Sheet
-4 Led blue lights
-3 2x4's
-carpeted slab of wood to mount amps on
-2 kicker 12" L5's
-Pioneer 800w amp
-Fiberglass Sheet
-4 Led blue lights
-3 2x4's
It's a sick set-up once again, but I kind of have to lean with JJashaa on this and say you spent a bit to much for what you have. If you like your music then hey let it be, 4000watt is mcnasty, plenty enough to collapse your lung with full bass on. WOOOOOOOOOO!
my cl hits hard i have 2 12' cvr kickers hooked up to a 1000watt volfhagen amp at the moment with maybe 2 more 12's comming in and a 2000watt volfhagen amp all fiberglassed in the trunk. looks good cant wait to post my pics.
no.. you still shop around lol.
having money is no reason to take it up the booty when you buy something
setup looks good though. i believe i'll stick with a aftermarket head unit and call it a day though... i'd prolly put 2 G's towards new paint on mine.
-pioneer deh-5900ib $150
-2 kicker 12" L5's $270
-kicker box ( i cut to fit all the way back against seats) $40
-Memphis pr.1000w amp $300
-Pioneer 800w amp model#?
-2 8 gauge wiring kits $40
-50ft 16 gauge speaker wire $15
-Fiberglass Sheet ??
-4 Led blue lights ??
-3 2x4's $9
-carpeted slab of wood to mount amps on $10-$15
-3 2x4's $9
Unless of course you bought everything from Crutchfield and paid full price for everything!
Check this site out to read up on the basics of wiring.
Not to take anything away from your set up man but 2 racks is alot for 2 12s a head unit and 2 amps. Maybe if you said you had it installed at a shop, but you did the work, you should have shopped around bro.
i got 2 alpine 15s type r one alpine v12 amp 1000 watts rms for 400 the amps like month old subs are a year old with a box and a used alpine iva-w205 borrowed 30 bucks for the trim kit and a bypass 30 bucks its loud enough lol
Rockstar is right, if you have money doesnt mean you should just blow it. Cause if you did have money, you would have a newer TL. I have a f900bt, same amp, and 12" kicker, and I didnt spend even half of what you spent. If you came in here saying you did all that for like 500, I would be inpressed, 2k sounds like you are trying to lie to kick it.
Sep 15, 2015 06:44 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
