Finally Rims are on!
Kinda dirty, but couldn't wait to show ya....
http://www.picturetrail.com/gallery/...354&uid=896953
FYI: 18" Racing Hart C5 Evolutions(+42 offset) with Sumitomo HTR+ 225/40/18
H&R OE Springs
btw, rear rubs a bit...I cut the tabs in the fender, but im going to have to trim some more off....with the 4 stock rims and tires in the trunk, I rubbed like crazy on every bump on the way home from the gas station...
H&R OE Springs
yea I have 18 Konig Absolutes (+45 offset) with Nitto 555 225.40.18 tires, and the body kit. I was thinking about gettin the sports, but now that ur sayin that you rub like crazy with weight and you have a +42 offset, I'm thinkin its pretty close, so I might just get the H&R OE's too. Does anyone know if a +42 compared to a +45 makes a HUGE difference when it comes to rubbing? anyone got any suggestions on which ones I should go with? By the way, I like the rims.
i have +45 w/ 235 falkens. first rubbing today!!!! stock springs, went over those huge gradual bump at UBC, couldn't see it at nite so went a bit fast, on the went down the springs compressed enough for the tires to rub against the fender
Lookin good, I've got the same wheels paired with comptech springs, no rubbing issues at all unless I have 3 people in the backseat, which only happened once. One word of caution with those wheels, don't use any spray on wheel cleaners on them, I learned the hard way. I did one wheel, and the clearcoat on the polished lip came off and looked horrible, had to get a replacement wheel. I looked on the bright side, at least I have a full size spare now just in case, but it still wasn't fun
I've been reading on this board that you're safe with and above 50 offset.....ha, I didn't research this well enough when i bought my wheels that have a 40 offset (konig glides). i'm running 215-45 17's and was rubbing consistently on the back so a local body shop here rolled the fenders on the entire arch. it's looks great, you can't even tell anything has been done and no more rubbing!
