Wiring LED strip??? Help??
Old Dec 25, 2009 | 10:27 AM
troper24996's Avatar
Question Wiring LED strip??? Help??
I have a 2000 TL base and want to wire a LED strip into the front grill.
---using a 12v strip----- what do I need..supplies...
Where do I start? What can I tap into for power?
Must have a switch! And be clean NO! Half ass like direct to battery.
HELP please!
Old Dec 25, 2009 | 01:23 PM
Skeete32's Avatar
NBP
do you want it to come on with your headlights or parking lights?
Old Dec 25, 2009 | 01:35 PM
I just want to turn it on with a switch..
Old Dec 25, 2009 | 01:43 PM
Skeete32's Avatar
NBP
just get a fog light installation manual and hook it up the same way. instead of it being the fog light it will be the led. If not on line go an parts store and say you lost the manual or ask if they have an open box and take it out
Old Dec 25, 2009 | 02:14 PM
anyone else have some suggestions.
Old Dec 25, 2009 | 02:43 PM
jaMezBOI's Avatar
philly flickin'
Originally Posted by skeete32
just get a fog light installation manual and hook it up the same way. Instead of it being the fog light it will be the led. If not on line go an parts store and say you lost the manual or ask if they have an open box and take it out
+1
Old Dec 25, 2009 | 02:49 PM
It's Clutch's Avatar
Hello Officer
why would you ask for another suggestion when the perfect answer has already been posted. No other good way than that.
Old Dec 25, 2009 | 04:25 PM
I just wanted to see if anyone else had done something similar or new of a diy post about this led lighting...Thanks
--can I just tap directly into my 12v lighter plug????
There is a hole in the firewall through this rubber plug that an old aftermarket alarm was wired to...I would just run the wire through that
---- Can I locate the 12v plug (wire) throgh the FUSE panel ????
Old Dec 25, 2009 | 04:49 PM
Hello Officer
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-01-03-civic-fogs-99-01-tl-624705/
This should help you with wiring and powering your LED strip as well as setting up a switch.
Old Dec 25, 2009 | 06:35 PM
LThouse's Avatar
99 NBP tl
Dont forget to post up picks when done
Old Dec 25, 2009 | 08:35 PM
Thank you! I'll post em when I finish.
Old Dec 25, 2009 | 08:42 PM
Hello Officer
no problem.
08KBP_VA
Oct 22, 2019 01:55 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
4drviper
Sep 23, 2015 07:42 PM
eastcoastguy
Sep 23, 2015 06:29 AM
