Wiring LED strip??? Help??
I have a 2000 TL base and want to wire a LED strip into the front grill.
---using a 12v strip----- what do I need..supplies...
Where do I start? What can I tap into for power?
Must have a switch! And be clean NO! Half ass like direct to battery.
HELP please!
HELP please!
just get a fog light installation manual and hook it up the same way. instead of it being the fog light it will be the led. If not on line go an parts store and say you lost the manual or ask if they have an open box and take it out
I just wanted to see if anyone else had done something similar or new of a diy post about this led lighting...Thanks
--can I just tap directly into my 12v lighter plug????
There is a hole in the firewall through this rubber plug that an old aftermarket alarm was wired to...I would just run the wire through that
---- Can I locate the 12v plug (wire) throgh the FUSE panel ????
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-01-03-civic-fogs-99-01-tl-624705/
This should help you with wiring and powering your LED strip as well as setting up a switch.
SUPRMN84
Oct 7, 2015 09:46 PM
4drviper
Sep 23, 2015 07:42 PM
