Who's running NOS???
Originally Posted by blk2001tlon19s
I had a Zex Dry kit prior to my turbo setup. Pretty easy install and worked great. I will be running another kit soon(i think though).
Originally Posted by sbuswell
what were you runnning 50, 75, 100? also did you have any problems with your engine while running it? I wouldn't mind a 50 or 75 kit with an on/off switch set for higher rpm's for the track or a once a month WTF race on the highway.
I had it regularly at 75 however I did have the jets for 100 also. Never had any problems with the engine or transmission while using the bottle on the car.
Did anyone have any tranny issues w/ it? I'm looking at setting it for like 3800-4000 RPM so I figured it would be OK as the car should be out of 2nd gear..most times..
Did anyone set it like this or did you do thye push a button set-up?
Also, I was told a wet system is safer on the motor as it send fuel w/ the No2 and is less dangerous to the engine...that and the purge system looks really cool...
Originally Posted by 1st timer
Did you ever take it to the track when you had nitrous set up?
With every other mod available the best time I had was 13.97 @101.3 if i remember correctly but that was like 2 years ago.
SinCityTLX
10-07-2015 01:24 PM
