what are ur koni yellow settings?
Im curious what settings people are using with koni yellows
...upper or lower perch?
...and firmness level? softest to hardest
...with what springs?
and if you post a pic that would be helpful too, thx
I can get you a nice deal on godspeed coilovers. Just PM me
Introducing the Godspeed Project Mono-SS coilover. The Mono-SS series is a new addition to our Godspeed Project suspension line and offers the bare minimum for what we believe an after-market coilover system should be without sacrificing reliability, quality and performance. Featuring a Mono-Tube shock, this series is built more for consumers who are on a budget but want the best bang for their buck. For a much more comfortable ride the Mono-SS all come with a Poly Urethane bushing in both the top hat and lower bracket for an improved ride instead of a spherical bearing which can be too stiff and noisy for some. The Mono-SS also caters to consumers who will be driving their cars on the daily and also occasional track days through the year. The Mono-SS is 16 way adjustable which allows you to fine tune the shock dampening to your liking. Whether you are driving 50 miles to work or setting a new personal best record on a local race track the Mono-SS will provide you with the performance you need to get the job done!
Features:
- Spring Rates, 12kg Front / 8kg Rear
- 16 Levels of Dampening
- Mono-Tube shock design
- Powder coated damper body
- Ride height and spring preload are completely separate (Ride height can be changed without touching spring preload)
- Poly Urethane bushing in both the top hat and lower bracket
- One Year Warranty from Date of Purchase
Features:
Adjust them to how you like them. Its trial and error. Tire/rim choice can all influence suspension settings and make it different from car to car. I spent the day taking the shock on and off to adjust settings before i found a good base point for my summer rim/tire setup. It rides completely different when i put my stock rims on with snow tires due to the difference in weight and size.
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
SUPRMN84
Oct 7, 2015 09:46 PM
