Type s swap
Type s swap
What's up ladies and gents , I'm kind of sort of new to this Forum and was wondering if you guys can help me out. With that being said I want to know exactly what I need to swap in a 2nd gen tl-s engine and trans into my base model . I'm sure plenty of ppl have asked this before just can't find the answers .. thanks
If you need a shop to do it, it will be too expensive to be worth it.
If you have the time and interest, you can do it for the cost of buying a wrecked Type S. It's not bad at all, I did it with little to no experience. You just need to be motivated (and have tools).
Technically you dont need anything special to get the motor to run. It is a direct bolt in, and will run with your stock ecu. To take full advantage of the Type-s motor though you will need to change/add/repin some of the harnesses and get the type-s ecu
We swapped a Type S engine in our Base 02 TL last year. The only thing extra i needed was a RPM switch to control the butterfly's in the manifold. You don't need the Harness or the Ecu really. But if you plan on running the Type S ECU then you will need the harness.I noticed the harness had plugs for the 2nd Throttle body that the Type S uses for VSA and to control the butterfly's in the manifold. You can throw the 2nd TB out and use a Rpm switch for the butterfly's like i did and your set.
Otherwise the base engine ECU will run the Type S engine just fine. Our TL has been running like this for over a year with no issues. The power difference of the Type S cams is noticeable even on the Base ECU. It just doesn't rev higher than the Base ECU which really isn't that big of a deal knowing the engine can rev higher. And oddly it gets better MPG's like that than my 03 Type-S( I have the base with the type S engine and a real 03 Type S) If you need anymore details Feel free to Pm me.
If you are using the ECU in the Base TL to run the TypeS engine the ECU is not going to ask for that TCS TB because it doesn't come with it. So if you toss that 2nd TB and use the Harness from the base engine it all plugs in as normal. You just bypass that Tb by removing it. Now if you want to use that 2nd TB you will have to use the harness from the Type-S engine along with the ECU. And that will control the butterfly in the manifold also. Basically the Base ECU doesn't have the butterflys to open. That's where the RPM Switch comes in. Also the Base engine doesn't have the VSA Traction control system so it isn't going to ask for it. The only extra plugs on the harness for the S is the butterfly plug and the VSA Tb control. Otherwise everything else is the same and plugs right in. Our car has had no engine lights since this swap last year. Runs and drives every day with zero issues and works as normal. Just has the extra Kick from having the S engine. I hope this makes sense.
I have a Type S Harness if you need one.
10-4...I have a couple Cl-s models in a junkyard where i am so grabbing the harness will be no issue however the keys might be a challenge. Now as far as the harness goes will I be looking into grabbing the harness from behind the dash/firewall as well as engine harness?
Can I just take the heads have em port an polished for an extra couple hp??
I have 02 Base CL coupe, I had the whole auto transmission issues and all. Even though I swapped a 06 TL auto trans into it currently, a dear friend helped me acquire a Type-S motor and 6 speed manual trans. I know of the whole clutch assembly to add and the braided line that will control the slave cylinder. Can't also forget the shifter assembly and routing the trans cables to the tranny. Otherwise I believe that the installation process was very easy since I took out the swap from a previous auto accord coupe.
I do have the Type-S engine harness and Type-S ECU, but what will be connection for the clutch safety switch?
Also In question about the VIn being encoded into the ecu, like when I go in for a auto inspection and the computer is reading a different vin on the ecu from the chassis of the car ?
I'm still doing the swap, But if these questions can be answered the I will be installing this swap much faster than my K swap project. and beside the CL 01-03 CL coupes are still sexy till this day. Younger Acura owners are still loving the boldness of this coupe since it stands out like the current euro competitive coupes.
ritchie2428
14
Sep 5, 2025 06:41 PM
LECKEY73
Feb 22, 2016 01:32 PM
GK83
Sep 13, 2014 12:48 AM
