type s IM
Old Feb 12, 2008 | 04:18 PM
00 acura tl's Avatar
Inspired
type s IM
hey guys im planning to put the type s manifold but i want to keep the tl-p TB if i get the OE spacer for the tl-p will it still bolt up right with the type s IM. thx
Old Feb 12, 2008 | 09:51 PM
NSXNEXT's Avatar
Yes but why would you want to do that? The 2.75" TB will restrict the amount of air getting into the IM and you probably won't see much if any gains.
Are you planning to hook up the bypass valve actuator? I still haven't got around to getting mine hooked up. I can definitely feel a big loss of power when VTEC kicks in since the second chamber is shut.
Old Feb 12, 2008 | 10:01 PM
sbuswell's Avatar
I need 2 more gears
NSXNEXT you gotta hook the actuator toan RPM switch man. With your mods that should prove to be a killer setup and quite a bit of power for a tl-p. I want a TL-S IM, lower IM, fuel rail and TB and then put a new CAI, maybe next year.
Old Feb 13, 2008 | 07:03 AM
fsttyms1's Avatar
Why would you put the larger intake on, but put a bottle neck with keeping the TL-P TB?? It would be pointless to do what you want.
Old Feb 13, 2008 | 08:21 AM
NSXNEXT's Avatar
Have everything ready to install, just haven't gotten around to installing it.
Recently installed an OEM TypeS airbox without the lower resonator. I had built a custom CAI but it was a bitch to keep clean.
Old Feb 13, 2008 | 01:19 PM
02type-s's Avatar
-Arsenic-
Don't waste your time and money. TL-S throttle body is a must when you are alreadly doing the manifolds. Get as much power as you can out of it.
Old Feb 13, 2008 | 01:38 PM
Inspired
man the TB is pricey
nsxnext im going to get the bypass valve actuator also
Old Feb 13, 2008 | 01:39 PM
Inspired
the only thing i didn't want to put the type s TB its cause i bought a aem v2 like a month ago. Will the aem v2 still mount on the type s TB?
Old Feb 13, 2008 | 02:17 PM
NSXNEXT's Avatar
Yes if you get a 2.75" to 3" hose adapter or really stretch the 2.75" coupler but again, you're not getting the proper airflow into the TB and IM since the V2 is 2.75" and the TB is 3".
Old Feb 13, 2008 | 02:20 PM
EL19's Avatar
yea dont put that V2 on the type s TB...i did that and once i changed the intake to a 3" intake i felt a BIG difference in power...if u wanna keep the V2 cut the 2.75" pipe off of it...open up the intake to 3" and have someone weld a 3" pipe where the 2.75" pipe used to be
Old Feb 13, 2008 | 05:21 PM
02type-s's Avatar
-Arsenic-
lol just sell the AEM for an intake made for a Type-S.
Old Feb 13, 2008 | 07:10 PM
fsttyms1's Avatar
Though im sure it will still make power over the stock tubing. If you find a welder in the area you could have them cut off the 2.75 pipe and weld a 3" section on pretty cheap
Old Feb 13, 2008 | 07:29 PM
sbuswell's Avatar
I need 2 more gears
In my post I stated TB. Of course I meant TL-S TB to match the rest of the parts. Then a TL-S CAI to match everything.
Old Feb 14, 2008 | 07:00 AM
fsttyms1's Avatar
My post was directed at the OP
Old Feb 14, 2008 | 07:58 AM
Inspired
okay i will cut the 2.75 inch pipe wel d a 3 inch
tommy--->i paid 335$ for the v2 with shipping if im going to sell it i will not get my money back it will be loss for me
Old Feb 14, 2008 | 08:10 AM
Inspired
im going to get the bypass valve actuator brand new but the IM and the TB i will get used. it won't cause me any probs right if i get them used?
Old Feb 14, 2008 | 08:45 AM
fsttyms1's Avatar
No why would it. As long as its in good shape and not damaged it will be just fine
Old Feb 14, 2008 | 08:46 AM
NSXNEXT's Avatar
The IM really doesn't have any parts that would go bad. Throttle body? You never know, could have a dirty IACV.
Ask the people you buy it from what the warranty is on it if there are problems.
Old Feb 14, 2008 | 09:00 AM
Inspired
ill try to find clean one, cause man a new tb cost some pennys.
how much hp will this conversion give like 5-8?
Old Feb 14, 2008 | 07:31 PM
sbuswell's Avatar
I need 2 more gears
my guess is a solid 10whp and definitely more low end toque.
Old Feb 14, 2008 | 09:47 PM
Inspired
do i have to change the lower intake also
Old Feb 14, 2008 | 09:52 PM
Inspired
if i change the IM, TB and buy a new bypass valve actuator. if i will be ordering the OE spacer witch model do i have to get type s?
Old Feb 15, 2008 | 08:19 AM
NSXNEXT's Avatar
The lower IM (a.k.a. injector bases) are the same for the TL and TLS for model years 00-03.
The 99 is the only one that is different. If memory serves me, the 99 TLP runners are egg shaped versus round on the others.
Old Feb 15, 2008 | 08:20 AM
NSXNEXT's Avatar
Charles Bennett
Jan 28, 2018 08:53 PM
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
