type S conversion??
Old Aug 1, 2010 | 05:17 PM
MKSHFT's Avatar
type S conversion??
wassup im new to these forums and was wondering if you guys could help me or give me some advice..
I plan on picking up a 99-01 TL and swapping in a j32a2 type s motor from a 02 model. I already have the J32a2 long block but it has a rod knock so i will be rebuilding it(considering stroking it to a 3.5L). I was wondering if anyone on these forums has done this conversion/swap yet.. any helpful info would be appreciated.. My main concern is the ECU, will a ECU from an 02-03 type s fit into an 99-01 TL? thanks in advance
Old Aug 1, 2010 | 05:58 PM
ANC297's Avatar
Bonki' Ehrite!
The ecu will fit, there are various members on here that have done the swap, along with some that have done the swap paired with the 6 speed swap...
Old Aug 1, 2010 | 08:16 PM
fsttyms1's Avatar
find a 00-01, wiring wise it will be easier as they came with the 5 speed and not the 4 speed
Old Aug 1, 2010 | 08:23 PM
MKSHFT's Avatar
thanks guy i appreciate the info.. just wondering do i need to use type s engine harness? and would it be better to use the type s trans or the stock non type s trans? I know they have alot of problems with the auto trans but i rather keep it simple for now.. thanks again!!
Old Aug 1, 2010 | 08:55 PM
YeuEmMaiMai's Avatar
sell your car buy a type S easier and less painful
Old Aug 1, 2010 | 10:01 PM
assclown's Avatar
2000 acura tl FPR
the type s ecu plugs right in
Old Aug 4, 2010 | 08:57 PM
AznWay's Avatar
Main thing is finding the harness. Pretty much all wire fit the same only thing different is speed senor connector, Temperature senor an get Type S ECU. I have done engine swap on 99 to Type S
Old Aug 4, 2010 | 10:49 PM
MurkyRiversTL's Avatar
COTM Coordinator
^ This. I know from experience.
Old Aug 5, 2010 | 10:10 AM
DC3328's Avatar
Your Garage
so you have the engine but dont have a car hmm.
why dont you put it into a different car?
Old Aug 9, 2010 | 02:01 AM
MKSHFT's Avatar
^i rather use this motor in the TL rather then put it in a civic or integra if thats what your asking? thanks for the advice guys
Old Aug 9, 2010 | 07:39 AM
assclown's Avatar
2000 acura tl FPR
you can do it like "idon'tknow" and pop it into an MR2 sexxxxxx
Old Aug 9, 2010 | 12:07 PM
DC3328's Avatar
Your Garage
hell no. fwd ftl.
MR2, S2000, Elise/Exige, an old Porsche, AE86 Corolla, 240sx, pontiac fiero, anything else it will fit in
Old Aug 10, 2010 | 02:10 PM
fresh00tlp's Avatar
9th Gear
I have a 2000 tlp.I have a j32a2 longblock and ecu in the garage. If i swap in the ecu will the key need to reprogrammed to that ecu? I also have the key that goes to the type-s ecu. I have the whole front clip of a cl-s. It was sliced in half by a tree.
Old Aug 10, 2010 | 08:37 PM
COTM Coordinator
If you have the ignition switch for that key then you should be good. Other wise you can have your original key programmed to the new ECU.
Old Aug 14, 2010 | 04:19 PM
fresh00tlp's Avatar
9th Gear
I have the type-s front clip, the whole swap. I also have another j32a2 longblock in the garage that I picked up from the local pick-a-part. Didnt need it but I grabbed it just cause it was a steal. So the A1 bottom end in my car is still pretty healthy, if I swap the a2 heads from the spare longblock on the a1 bottom, and install my type-s ecu, should it run pretty much like a type-s? I dont feel like doing the whole swap untill its time for a tranny, which I know will be eventually lol.
Old Aug 14, 2010 | 06:36 PM
assclown's Avatar
2000 acura tl FPR
i'm doing type s swap
Old Aug 14, 2010 | 07:01 PM
V_Langs_3.2TL's Avatar
Rice Patrol
nice.
I personally like the way the 99-01 looks with the straight headlights instead of the 02-03 bug eyes
Old Aug 14, 2010 | 07:09 PM
assclown's Avatar
2000 acura tl FPR
yeah, and some more goodies
Old Aug 14, 2010 | 07:35 PM
COTM Coordinator
Very nice.... Reminds me of mine
mvidal6
ILX
Nov 14, 2015 07:43 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
